PIX 501 internal route statement
Not that familiar with PIX. I added a route statement to send traffic for remote locations to the VPN box on the same subnet as the PIX:
route inside 172.16.0.0 255.255.0.0 192.168.1.17 1
I can ping 172.16.x.x addresses from the PIX box, but not from hosts with the PIX as the default gateway. Did I miss something else?
Re: PIX 501 internal route statement
By default PIX firewalls will not allow a packet to ingress/egress on the same interface.
7.0+ code trains will allow you to override this, but I don't think a 501 will support it.
If you have a spare interface on your 501 I would place the VPN box in a DMZ by itself so that the traffic is routed between firewall interfaces to get around this.
Thanks, that answers my question. As usual, the real solution is more involved than I had hoped.
Daniel,
PIX doesn't route packets out the same interface in which the packets arrived on. You may have to add a static route(s) to the remote locations on the host to point to the VPN device. Another option is to change the gateway of hosts to point to a router, if one is available, on the same segment which can then forward packets to VPN device or firewall depending on the destination.
Sundar
133
