Community Member
pix 501 or 506e
Hi all, Can anyone tell me what is the better firewall, the 501 or the 506e, and can you configure any of these via gui, web page rather than cli, I just want to put one infront of my router at home for internet, can anyone give me an easy config for this ?
cheers
Carl
Re: pix 501 or 506e
Hi Carl,
Cisco PIX 506E provides two autosensing Fast Ethernet (10/100) interfaces. The Cisco PIX 506E delivers up to 100 Mbps of firewall throughput, 16 Mbps of Triple Data Encryption Standard (3DES) VPN throughput, and 30 Mbps of Advanced Encryption Standard-128 (AES) VPN throughput.
The PIX 501 includes an integrated 4-port Fast Ethernet (10/100) switch and a Fast Ethernet (10/100) interface. Ideal for securing high-speed broadband environments, the Cisco PIX 501 delivers up to 60 Mbps of firewall throughput, 3 Mbps of Triple Data Encryption Standard (3DES) VPN throughput, and 4.5 Mbps of Advanced Encryption Standard-128 (AES) VPN throughput
So 506 has more firewall and vpn throughput but has only 2 FE ports. Cisco 501 has 4 port switch and a FE interface, but has a little less throughput than 506. I would suggest 506E
-amit singh
Community Member
Re: pix 501 or 506e
Do any of these have a dmz port, and is there an easy way to configure for broadband environments ?
Community Member
Re: pix 501 or 506e
No, both 501/506 have only two ports: inside and outside, without any possibility to upgrade. 501 has a 4ports switch, but it is connected to inside interface.
It depends what's your understanding of the word: easy :-) For an experienced Cisco Eng. it takes a few minutes...
190
