Webcast-Catalyst9k
Pix 515 Static translation problem
I'm having some problems connecting to an address specified in the static translation command (194.70.60.3). I can ping the outside interface 194.70.60.2 no probs. But not this .3 address.
The Pix outside interface is connected to a Router 194.70.60.1 and all routing is correct.
Below is my Pix config.. I for one can't see what I have done wrong.. A fresh pair of eyes may spot the issue straight way.
nameif ethernet0 outside security0
nameif ethernet1 inside security100
interface ethernet0 100full
interface ethernet1 100full
ip address outside 194.70.60.2 255.255.255.224
ip address inside 10.250.1.10 225 255.255.255.252
hostname MIL-PIX-001
arp timeout 14400
no failover
logging buffered debugging
nat (outside) 0 0.0.0.0 0.0.0.0
nat (inside) 0 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 194.70.60.1 1
route inside 10.0.0.0 255.0.0.0 10.250.1.9
access-list ping_acl permit icmp any any
access-group ping_acl in interface inside
access-group ping_acl in interface outside
Static (inside,outside) 194.70.60.3 10.250.1.9 netmask 255.255.255.255
Bronze
Re: Pix 515 Static translation problem
The issue may be due to default implicit deny statement in the access list configuration. To overcome this issue configure permit ip any any command at the end of the configuration.
Open a TCP port with the AccessList. Try a telnet to port 445 (if 10.250.1.9 is a Windows Station). Does that function?
Which PIX OS version is running?
best regards,
marco
change the acl to
access-list-list ping_acl permit icmp any any eq echo
Which device is 10.250.1.9. I see that you have a static route for you 10.0.0.0 subnet pointing towards it. Can you ping this IP from internal subnet.
You can also try changing the ACL to the following:
access-list-list ping_acl permit icmp any any eq echo-reply
HTH,
-amit singh
143
