pleas frind i need help in switch 2900XL
hi frind
I need help . i have cisco switch 2900 XL , I install new image , but when it reload , this appear for me
flashfs[1]: Initialization complete.
...done Initializing C2900XL flash.
C2900XL POST: System Board Test: Passed
C2900XL POST: Daughter Card Test: Passed
C2900XL POST: CPU Buffer Test: Passed
C2900XL POST: CPU Notify RAM Test: Passed
C2900XL POST: CPU Interface Test: Passed
C2900XL POST: Testing Switch Core: Passed
C2900XL POST: Testing Buffer Table: Passed
C2900XL POST: Data Buffer Test: Passed
C2900XL POST: Configuring Switch Parameters: Passed
C2900XL POST: Ethernet Controller Test: Passed
C2900XL POST: MII Test: Passed
cisco WS-C2924-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
IOS (tm) C2900XL Software (C2900XL-C3H2L9S-M), Version 12.0(5)WC17, RELEASE SOFT
WARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:28 by antonino
00:00:31: %IMAGE_MISMATCH-3-MALIBU_IMAGE_MISMATCH:
LRE firmware not supported by switch hardware.
Please download a non-LRE image.
what is that , and what is the correct imag (.bin) to install in it
regards ...
Re: pleas frind i need help in switch 2900XL
What is the image (full image name) you are trying to load to the switch?
You should be using c2900xl-c3h2s-mz.120-5.WC17.bin. I guess you might have
downloaded c2900xl-c3h2l9s-mz.120-5.WC17.bin which is for LRE switches.
Hope this helps.
NT
dear frind ...
I am very grateful  for you're help , yes i downloaded this image (c2900xl-c3h2l9s-mz.120-5.WC17.bin) ,
so i will tray to download the new image ,
hint
can you tell me how i can know the correct image i must download
regards
You should look for C2900 IOS image (without keyword LRE). Here is the link
for the latest image:
http://tinyurl.com/2dnsvy8
Hope this helps.
NT
Dear
when i inter u'r link this appear for me
no item found
can help me
regards ..
Please try this link:
http://tinyurl.com/5fj9e8
NT
ok dear
i am very grateful for u'r response , can u tell me which file from this site i choice
thank you
c2900xl-c3h2s-mz.120-5.WC17.bin should work.
NT
ok dear ..
i will try and tell u
regards
To add to my earlier post, c2900xl-c3h2l9s-mz.120-5.WC17.bin is C2900XL LRE
IOS IMAGE where as you need C2900 IOS IMAGE (if you are downloading it from
Cisco Site, it is 3rd one from the top I believe).
Hope this helps.
NT
dear i downlad this image
but this error apear
Initializing C2900XL flash...
flashfs[1]: 2 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 3612672
flashfs[1]: Bytes used: 1933312
flashfs[1]: Bytes available: 1679360
flashfs[1]: flashfs fsck took 6 seconds.
s of memory.
Processor board ID FAB0345Y0N9, with hardware revision 0x01
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:30:94:63:0B:C0
Motherboard assembly number: 73-3382-07
Power supply part number: 34-0834-01
Motherboard serial number: FAB034466K0
Power supply serial number: DAB03352M83
Model revision number: A0
Model number: WS-C2924-XL-A
System serial number: FAB0345Y0N9
Press RETURN to get started!
C2900XL INIT: Complete
00:00:21: %LRE_UPGRADE-4-INIT_RESOURCE: cannot locate lre firmware files
00:00:29: %SYS-5-CONFIG: Configured from NVRAM by console
00:00:31: %SYS-5-RESTART: System restarted --
WARE (fc1)
where the problem
regards ..
The image you downloaded has "l9" which means it is for LRE platform. Download the image that does not have "l9" in its name.
NT
dear all
i install new image in the problem still the same , please frind where the problem , i realy need help
thank you ...
what is happen no buddy can help me
to resolve my problem ???????
Purple
   You should only be using this image .  c2900xl-c3h2s-mz.120-5.WC17.bin .    Verify  this image is in flash. Do a dir flash:  .  Did you set your boot statement once you downloaded the image ?    "boot system flash:c2900xl-c3h2s-mz.120-5.WC17.bin .  Then do a write mem  command and reload.
dear glen
i do that , and make boot from it but when i reload it during the reload the image , the error appear for me
this error for the controlar
% Invalid input detected at '^' marker
and  when i [use this image ( c2900xl-c3h2l9s-mz.120-5.WC17.bin) this error not appear , but this appear
and also canot add any VLAN
so where the problem , i hop to help me
Can you please post the output of "show flash:" and "show run | I boot"
commands here?
NT
Switch>sh version
WARE (fc1)
Image text-base: 0x00003000, data-base: 0x0038A0D8
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 1 hour, 19 minutes
System image file is "flash:c2900xl-c3h2l9s-mz.120-5.WC17.bin"
s of memory.
Last reset from power-on
Configuration register is 0xF
Switch#dir flash:
Directory of flash:/
  2  -rwx     1929856   Mar 01 1993 00:50:55  c2900xl-c3h2l9s-mz.120-5.WC17.bin
  3  -rwx          45   Mar 01 1993 00:52:13  env_vars
  4  -rwx        1021   Mar 01 1993 00:53:05  config.text
3612672 bytes total (1679872 bytes free)
Switch#show boot
BOOT path-list:      flash:c2900xl-c3h2l9s-mz.120-5.WC17.bin
Config file:         flash:config.text
Enable Break:        no
Manual Boot:         no
HELPER path-list:
NVRAM/Config file
      buffer size:   32768
any body found the problem ??????????????
You still have incorrect image in the switch flash. Please do the following:
-- Login into Cisco.com and download c2900xl-c3h2s-mz.120-5.WC17.bin image
-- On Google, search for TFTPd32 and download it onto your PC
-- Install TFTPd32 on your PC
-- Ping the 2900XL switch from your PC. Make sure that the PING is
successful
-- Ping your PC from 2900XL and make sure that it is successful as well. If
the PING is not successful, check your PC and turn off any firewall
(Windows/Antivirus Software/VPN) and try again. Now start the TFTPd32
program (double click on the shortcut on your desktop)
-- Move the image you had downloaded earlier to C:/Program Files/tftpd32
folder on your PC
-- Now, delete the old image from the 2900XL
switch#delete flash:/c2900xl-c3h2l9s-mz.120-5.WC17.bin
-- Now copy the new image to the switch:
switch#copy tftp: flash:
Address or name of remote host []?
Source filename []? c2900xl-c3h2s-mz.120-5.WC17.bin
Destination filename ?
Now reboot the switch. You should be able to reboot with the new image.
Hope this helps.
NT
dear ..
i install this image c2900xl-c3h2s-mz.120-5.WC17.bin through Xmodem , after the install finsh and reload it , the error appear for me
% Invalid input detected at '^' marker.
so  now whta u say me to do
You are getting those because some configuration line that were entered by
the earlier software version are not compatible with the new image. This
happens when you boot up the switch first time with the new image. If you
issue a "write mem" command and reload, you should not see that error
message again.
Hope this helps.
NT
dear Naqaraja..
i install the image (c2900xl-c3h2s-mz.120-5.WC17.bin) and write memory then reload it
this appear for me after reload
controller LongReachEthernet 0
controller LongReachEthernet 1
controller LongReachEthernet 2
controller LongReachEthernet 3
controller LongReachEthernet 5
controller LongReachEthernet 6
controller LongReachEthernet 7
controller LongReachEthernet 8
controller LongReachEthernet 9
controller LongReachEthernet 10
controller LongReachEthernet 11
controller LongReachEthernet 12
controller LongReachEthernet 13
controller LongReachEthernet 14
controller LongReachEthernet 15
controller LongReachEthernet 16
controller LongReachEthernet 17
controller LongReachEthernet 18
controller LongReachEthernet 19
controller LongReachEthernet 20
controller LongReachEthernet 21
controller LongReachEthernet 22
controller LongReachEthernet 23
Switch#show boot
BOOT path-list:      flash:c2900xl-c3h2s-mz.120-5.WC17.bin
Enable Break:        no
Manual Boot:         no
HELPER path-list:
NVRAM/Config file
      buffer size:   32768
Switch#dir flash:
  2  -rwx     1811968   Mar 01 1993 00:50:37  c2900xl-c3h2s-mz.120-5.WC17.bin
  4  -rwx          43   Mar 01 1993 00:55:05  env_vars
  5  -rwx        1827   Mar 01 1993 00:55:59  config.text
3612672 bytes total (1797120 bytes free)
So Now where the problem ???????
what happend ,no body can reslove mr trouble ???????????
Purple
  You might try deleting the "config.txt"  file in flash and then reload the switch and see what happens .
Dear Naqaraja , glen
and all my friend that response with my problem
I think my problem is resolve i now check it , iam very gratefull for all
regards ...
724
