Please help !!!! How do i force traffic to use the uplink port?
pingcrosby
Hello
I am a network newbie so be gentle - can somebody help me with what I think is a trivial problem.  I have 2 switches (Cisco 3020) linked together via an uplink port and a number of servers (blades in this case) attached.  On each server/blade Nic0 is physically attached to Switch0 and Nic1 is physically attached to Switch1.
Network communication between all servers is ok as long as i hit the correct network card via the correct switch.. Eg from 10.10.11.203 if i hit a nic that is physically attached, it all works fine.  It is when i want to send traffic across the switches i have issues.  For example if i send traffic from 10.10.11.203 to 10.10.11.16 the traffic does not traverse switches via gi0/24, instead it insists on using gi0/19 which is attached to a switch (not uplinked) on another network which fails.
I need to somehow configure the switch(es) so that Switch 0 always attempts to use Switch 1 via the uplink before finally the decision is made to send traffic upwards over gi0/19 and onwards to other switches on the network.
Any help whatsoever is very much appreciated.
(1) Traceroute from (SW0) with SW1-gi0/19 enabled running traceroute from 10.10.11.203 to 10.10.11.16
Translating IP to mac .....
10.10.11.203 => 0022.649e.3ec6
10.10.11.16 => 0022.649b.dce2
Source 0022.649e.3ec6 found on SW0
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/19
Unable to send a l2trace request to 192.168.20.5. Timed out
Layer2 trace aborted.
(2) Traceroute from (SW0) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.116
10.10.11.116 => 0022.649b.dce4
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/16
Destination 0022.649b.dce4 found on SW0
Layer2 trace completed.
(3) Traceroute from (SW1) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.16
(4) Traceroute from (SW1) with SW1-gi0/19 enabled running  traceroute from 10.10.11.203 to 10.10.11.116
(5) Traceroute from (SW0) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.16
1 SW0 (10.10.11.30) : Gi0/17 => Gi0/24
2 SW1 (10.10.11.31) : Gi0/24 => Gi0/16
Destination 0022.649b.dce2 found on SW1
Layer 2 trace completed
(6) Traceroute from (SW0) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
(7) Traceroute from (SW1) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
(8) Traceroute from (SW1) with SW1-gi0/19 disabled running  traceroute from 10.10.11.203 to 10.10.11.116
Switch 0 Running Config
version 12.2
no service pad
service sequence-numbers
hostname SW0
boot-start-marker
boot-end-marker
enable secret 5 $1$kDjk$GQ9ITEuCUwhGVFptPE2t9/
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
vlan internal allocation policy ascending
ip tftp source-interface FastEthernet0
ip address dhcp
interface GigabitEthernet0/1
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
description G5 Uplink
spanning-tree portfast trunk
interface GigabitEthernet0/18
interface GigabitEthernet0/19
description Dev Network Uplink
media-type rj45
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description X-Uplink Port
media-type internal
interface Vlan1
ip address 10.10.11.30 255.255.255.0
ip classless
ip http server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password Passw0rd123
login
line vty 5 15
login
end
Switch 1 Running Config
version 12.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$XR9L$VATn0pC6x/SxtOrhv1frA0
no aaa new-model
ip subnet-zero
ip address dhcp
shutdown
media-type rj45
media-type internal
interface Vlan1
ip address 10.10.11.31 255.255.255.0
ip classless
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
AxiomConsulting
Steve,
I havent had a chance to fully read the configs and traces you posted, so apologies if my answer is incorrect, however it sounds to me asthough there are 3 switches in the network, the 2 x 3020 and the upstream switch (attached to gig0/19).
Spanning tree may have put the link between the 2 x 3020 in to block to avoid any switching loops, therefore traffic will go via gig0/19.
Please run show 'spanning tree blockedports' on the 2 x 3020 to see if this is the case, if so you can adjust the STP config according.
Kind regards
Steve
Many many thanks for this heads up..
Running ... the following commands - i got this information...
I have no idea if its relevant, however i see that gi0/19 has a cost of 23 for SW1 and 3023 for SW0
Does this shed any light -- sorry for my total lack of knowledge on this ....
SW0#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32768
             Address     0007.85e7.2f00
             Cost        3023
             Port        19 (GigabitEthernet0/19)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    49153  (priority 49152 sys-id-ext 1)
             Address     0023.05dd.5d00
             Aging Time  300 sec
  Uplinkfast enabled
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 3004      128.1    P2p Edge
Gi0/2               Desg FWD 3004      128.2    P2p Edge
Gi0/3               Desg FWD 3004      128.3    P2p Edge
Gi0/4               Desg FWD 3004      128.4    P2p Edge
Gi0/5               Desg FWD 3004      128.5    P2p Edge
Gi0/6               Desg FWD 3004      128.6    P2p Edge
Gi0/7               Desg FWD 3004      128.7    P2p Edge
Gi0/8               Desg FWD 3004      128.8    P2p Edge
Gi0/9               Desg FWD 3004      128.9    P2p Edge
Gi0/10              Desg FWD 3004      128.10   P2p Edge
Gi0/11              Desg FWD 3004      128.11   P2p Edge
Gi0/12              Desg FWD 3004      128.12   P2p Edge
Gi0/13              Desg FWD 3004      128.13   P2p Edge
Gi0/14              Desg FWD 3004      128.14   P2p Edge
Gi0/15              Desg FWD 3004      128.15   P2p Edge
Gi0/16              Desg FWD 3004      128.16   P2p Edge
Gi0/17              Desg FWD 3004      128.17   P2p Edge
Gi0/19              Root FWD 3019      128.19   Shr
Gi0/24              Desg FWD 3004      128.24   P2p
SW0#show spanning-tree blockedports
Name                 Blocked Interfaces List
Number of blocked ports (segments) in the system : 0
SW0#sh span root
                                        Root    Hello Max Fwd
Vlan                   Root ID          Cost    Time  Age Dly  Root Port
VLAN0001         32768 0007.85e7.2f00      3023    2   20  15  Gi0/19
And on Switch 1
SW1#show spanning-tree
VLAN0001
             Cost        23
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     0023.05dd.3880
             Aging Time  300 sec
Gi0/1               Desg FWD 4         128.1    P2p Edge
Gi0/2               Desg FWD 4         128.2    P2p Edge
Gi0/3               Desg FWD 4         128.3    P2p Edge
Gi0/4               Desg FWD 4         128.4    P2p Edge
Gi0/5               Desg FWD 4         128.5    P2p Edge
Gi0/6               Desg FWD 4         128.6    P2p Edge
Gi0/7               Desg FWD 4         128.7    P2p Edge
Gi0/8               Desg FWD 4         128.8    P2p Edge
Gi0/9               Desg FWD 4         128.9    P2p Edge
Gi0/10              Desg FWD 4         128.10   P2p Edge
Gi0/11              Desg FWD 4         128.11   P2p Edge
Gi0/12              Desg FWD 4         128.12   P2p Edge
Gi0/13              Desg FWD 4         128.13   P2p Edge
Gi0/14              Desg FWD 4         128.14   P2p Edge
Gi0/15              Desg FWD 4         128.15   P2p Edge
Gi0/16              Desg FWD 4         128.16   P2p Edge
Gi0/19              Root FWD 19        128.19   Shr
Gi0/24              Desg FWD 4         128.24   P2p
SW1#show spanning-tree blockedports
SW1#sh span root
                                        Root    Hello Max Fwd
VLAN0001         32768 0007.85e7.2f00        23    2   20  15  Gi0/19
jason.henderson
Hi Steve,
I haven't read through the config, but whenever i see a port cost above 3000 i think uplinkfast.  Have you got uplinkfast enabled on one of the switches?
Jason.
Yes portfast is enabled on the switch
Should it be??
I thought portfast just allowed the switch to fail over via the uplink quickly.
Also i notice that on SW0 gi0/24 has the "orange" disabled light on ...is this relevant...i assume it should be "enabled" I have not disabled it, it seems to "disable" itself automatically.
