Webcast-Catalyst9k
PLEX Media Setup
Hello
Im trying to setup a 2811 router to forward films to my TV from my PC
The software is called PLEX MEDIA and its a progrom that is installed on the PC and there is an App on the TV that links up.
Before it was working when I had my normal Virginmedia Super Hub, it was basicly plug and play, however after I connected the 2811 router it has now stopped working and the app on the TV is not able to connect to the PC.  The TV is connected ok via wireless so no problems on that side.
The VM Super Hub (router/hub) is now in modem mode and my main router is the 2811. I access the libary through a web browser on the PC which points to my hardrive with all the films on. In the address bar on the browser its says:
http://127.0.0.1:32400/web/index.html#!/dashboard
I read on PLEX MEDIAs website that I need to configure port forwarding.
http://wiki.plexapp.com/index.php/MyPlex#Automatic_Configuration
Any ideas?
back to school!!
2 ACCEPTED SOLUTIONS
PLEX Media Setup
Where is the router located in relation to wireless? Are they not on the same subnet or do you have vlans set up? We're going to need more information....
Is the app on the TV a Roku box or something similar, or does your TV make a connection via a built-in wireless adapter? If everything is internal, you won't need to port forward unless you're trying to access MyPlex in which case you would...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
 Hello, Both the server and
 Both the server and Plex server have to be in the same subnet. Otherwise, the host will not see the   server. Looks like the Plex server sends broadcast to all hosts host of the same subnet. As a workaround, put your server in the Wireless subnet just so your TV seems it. Hope this works.
PLEX Media Setup
HTH,
John
PLEX Media Setup
The router, PC and TV  are located in my house, the TV has built in wireless and it also has an Ethernet jack on the rear (LG 47LA620V LED HD 1080p 3D Smart TV, 47) and the 2811 router has a wireless interface installed. I know the TV is connect because theres another App on the TV which is a browser and it can get out to internet.
Its not an Roku box or any other external device it all built into TV and this app just points to my PCs harddrive which contains the films.
My config is below:
CORE#sh run
Building configuration...
Current configuration : 5618 bytes
! Last configuration change at 14:09:07 UTC Thu Sep 19 2013 by James
version 15.1
service password-encryption
hostname CORE
boot-start-marker
boot-end-marker
logging buffered 64000
enable secret #########################
aaa new-model
aaa authentication login default local
aaa session-id common
dot11 syslog
dot11 ssid MATRIX
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid
wpa-psk ascii 7 ################################
dot11 wpa handshake timeout 2000
ip source-route
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.19
ip dhcp excluded-address 192.168.0.61 192.168.0.254
ip dhcp excluded-address 172.0.0.1 172.0.0.10
ip dhcp pool LAN_Addresses
import all
network 192.168.0.0 255.255.255.0
dns-server 8.8.8.8 4.2.2.2
default-router 192.168.0.1
lease 5
ip dhcp pool MATRIX
import all
network 172.0.0.0 255.255.255.0
default-router 172.0.0.1
lease 5
no ip domain lookup
ip domain name #########################
no ipv6 cef
voice-card 0
crypto pki trustpoint TP-self-signed-3845826623
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3845826623
revocation-check none
crypto pki certificate chain TP-self-signed-3845826623
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383435 38323636 3233301E 170D3133 30383235 30363031
  31385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38343538
  32363632 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009FF5 DA191624 A7ECAE35 A3F660AB A049B91F CB83F93F 888EB00D F5E2C20E
  83486395 E7069E1D 36BD1EEB 12AFCE88 2E8F5320 52E67F70 3F4716E9 97B1F33E
  0147A66D D573E9BC 36D35EA1 226D723B FAEDDCB2 C263511B DA745A66 8798BCEC
  F581248B FCD39380 FE92CEB9 09328BCD 71F9D1E1 BCCCB9DB EFA1DC22 ED7CF8BD
  25FD0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 143D0167 51FECFA9 ED03DF31 6B0A562E E10A9300 AE301D06
  03551D0E 04160414 3D016751 FECFA9ED 03DF316B 0A562EE1 0A9300AE 300D0609
  2A864886 F70D0101 04050003 8181006B C454436A 370AC181 BBA4017F 41E3DFD2
  CFE9665B 80F797DC B7130067 318318F9 094A4672 5BA2A50F 80EC1225 4C958474
  E309731D 9E4E5265 B861BAF0 36E4996B B396CB6C BF210CE6 59F3D165 441C2302
  3693441B DB45704D 5A6A15F5 79F939F9 6A9DDA84 DFDF5D11 E729D505 A1692E21
  2D95292C 6AC1263E FB35C46E 6D6874
        quit
license udi pid CISCO2811 sn FCZ09237316
username #################### privilege 15 secret 4 ############################################
redundancy
interface FastEthernet0/0
description CONNECTION TO MODEM>ISP$ETH-WAN$
ip address dhcp
ip access-group INTERNET_FILTERS in
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
no cdp enable
interface FastEthernet0/1
description CONNECTION TO LAB
ip address 192.168.10.20 255.255.255.240
ip nat inside
duplex full
speed 100
interface Dot11Radio0/2/0
description WLAN TO MOBILE USERS
bandwidth 10000000
ip address 172.0.0.1 255.255.255.0
ip nat inside
encryption mode ciphers tkip
ssid MATRIX
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
vlan-id dot1q 2
  description WIRELESS VLAN
  exit-vlan-config
interface FastEthernet0/0/0
description CONNECTION TO CORE PC
no ip address
interface FastEthernet0/0/1
description CONNECTION TO PS3
no ip address
duplex full
speed 100
interface FastEthernet0/0/2
description CONNECTION TO ACCESS SERVER
no ip address
interface FastEthernet0/0/3
no ip address
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Serial1/4
no ip address
shutdown
interface Serial1/5
no ip address
shutdown
interface Serial1/6
no ip address
shutdown
interface Serial1/7
no ip address
shutdown
interface Vlan1
description MANAGEMENT INTERFACE
bandwidth 10000000
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source list 2 interface FastEthernet0/0 overload
ip access-list extended INTERNET_FILTER
permit tcp any any established
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 2 permit 172.0.0.0 0.0.0.255
control-plane
mgcp profile default
alias exec s show ip interface brief
alias exec rc show running-config
alias exec r show ip route
alias exec v show version
banner motd ^CCCCC
###DO NOT LOG ON AUTHORIZED PERSONNEL ONLY####
^C
line con 0
exec-timeout 100 0
password 7 #############
logging synchronous
line aux 0
exec-timeout 30 0
password 7 ##################
logging synchronous
line vty 0 4
access-class 70 in
exec-timeout 0 0
privilege level 15
password 7 #####################
logging synchronous
transport input telnet ssh
scheduler allocate 20000 1000
end
back to school!!
PLEX Media Setup
What subnet is the PC and TV on? From the config, I don't see a reason why you'd be blocked. If your TV connects to MATRIX, the routing is all done on the router, so your TV destined to, say Fa0/1, wouldn't be blocked. Do you have any vlans or firewalls between you and this device?
HTH,
John
2954
