Webcast-Catalyst9k
Plz help mw with PPTP with multicast enable
Hi ,
ive setup a pptp server on router  , but i want to make sure that multicast udp packets are exchanging between my local lan and users that come by pptp tunel
here is my config of router :
cisco900#sh run
no ipv6 cef
ip source-route
ip cef
ip multicast-routing
vpdn enable
vpdn-group 1
 ! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
 l2tp tunnel timeout no-session 15
vpdn-group 2
 ! Default L2TP VPDN group
 accept-dialin
  protocol l2tp
interface GigabitEthernet0/0
 ip address x.x.x.x 255.255.255.0
 ip pim dense-mode
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.20.30.1 255.255.255.0
 ip pim dense-mode
 ip nat inside
 ip igmp join-group 224.17.2.148
 ip igmp join-group 224.17.1.148
 ip igmp join-group 224.1.1.1
 duplex auto
 speed 100
interface Virtual-PPP3
 no ip address
interface Virtual-Template1
 ip unnumbered GigabitEthernet0/0
 ip pim dense-mode
 ip nat inside
 ip igmp join-group 224.100.100.100
 peer default ip address pool PPTP
 no keepalive
 ppp encrypt mppe 128
 ppp authentication ms-chap ms-chap-v2 DRVIRUS
 ppp authorization DRVIRUS
interface vmi3
 no ip address
 mode bypass
router eigrp 1
 network 0.0.0.0
 network 85.252.160.200 0.0.0.0
ip local pool PPTP 10.11.12.1 10.11.12.100
ip forward-protocol nd
ip nat inside source list INTERNET interface GigabitEthernet0/0 overload
ip nat inside source list NATPPTP interface GigabitEthernet0/0 overload
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
Everyone's tags (1)
1 REPLY
i cant recive multicast on my
i cant recive multicast on my pc , i mean when i run wireshark i only have heloo pim2 messages .
ive added eigrp for test , and i could reciver 224.0.0.10 from router.
but i want somebody expert to have a look on my config above and make sure it is correct to send & recive multicast packets
regards
164
