POE 3560 Issue after IOS upgrade
I having issue where 6 WLAN AP's not coming back uo after reboot and IOS upgrade of 3560 POE swtiches - . Prior to changes here most if not all ALL the 23 Aps were mainly on one switch, Now after these changes they are now spread over three switches ( 3560's) - with 17 coming back on line
I am sure its not the power limitation of the switch(s) as the one switch I am TS at present had a fairly large allocation of the aps attached prior to ios upgrade and reload. and the available power value now showing is applicable.for 8 AP's
I have tried various TS steps to try and bring them back up - A couple of things I would like to try but I am restricted to do so is to check the APS physically or downgrade the ios!
Any input on this matter would be truly appreciated.- (attached is the log buffer debug)
res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
Hall of Fame Super Gold
c3560-ipbase-mz.122-25.SEE2
c3560-ipbase-mz.122-25.SEE2.bin
You upgraded the IOS to the switch?  I shudder at the thought of what old version did you upgrade FROM.
Available:370.0(w)  Used:110.4(w)  Remaining:259.6(w)
You've got more than enough PoE left.
Only two things comes to my mind:
1.   Cable issue - Unfortunately, the 3560 is a non-GigabitEthernet and this particular sub-model does NOT support TDR.
2.  Hardware failure - Read THIS.
Hello Cheers leo"You upgraded
Hello
Cheers leo
"You upgraded the IOS to the switch?  I shudder at the thought of what old version did you upgrade FROM."  - Considering the importance of this IOS upgrade I am on the understaning this is a major step for them! - Crazy
Thanks for the url link mush appriecated
res
Paul
ROF&LMAO!
From 12.X to 12.2(25)SEE2 is a "major step"?
46
