Webcast-Catalyst9k
POE 3560 Switch Queue 3/ Weight 2 drops
Hi All,
3560 POE switches: WS-C3560E-48PD
IOS : 12.2(37)SE
Auto QOS is enabled using the command: auto qos voip trust. Phones are connected and evetrything works fine. In general check, using the command : "sh platform port-asic stats drop"- all the switch ports (where the phone are connected) showing drops in couple of switches. Please see the attached drop log and also attached existing qos & int config. No issues at this time but interested to know what causing the drops on these switches. All switches running same IOS.
Thank you in advance
MS
296
