Webcast-Catalyst9k
PoE 802.3af "show power inline" command output
Hi Guys,
If I have the following command output below, does the class N/A mean that the device (which is a cisco 7961 phone) is not using the IEEE 802.3af standard and using Cisco's pre-standard for PoE?
Many thx indeed,
Ken
Switch#sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 151.2 218.8
Interface Admin Oper Power Device Class
(Watts)
Fa1/0/1 auto on 6.3 Cisco IP Phone 7960 n/a
Fa1/0/2 auto on 6.3 Cisco IP Phone 7960 n/a
Fa1/0/3 auto on 6.3 Cisco IP Phone 7960 n/a
Re: PoE 802.3af "show power inline" command output
Hi Friend,
Can you confirm the exact model of your IP Phone?
Ankur
Hi Ankur :)
It's a 7961
Many thx
Ken
Bronze
Do the phones have their power supplies plugged in as well as being plugged into the switch? Depending on which was plugged in first dictates which power supply the phone draws from.
there is no external power :))
624
