12-19-2011 02:33 PM - edited 03-07-2019 03:58 AM
We are getting a replacement NME-16ES module shortly. I don't see a console port on these pups. Once installed - how can we add the configuration from the failed NME-16ES? It's been a couple of years since I initiall set these up. Thank you.
Solved! Go to Solution.
12-19-2011 03:16 PM
This is module that gets inserted into a 2900, 3900, etc... There is no console port. You login to the router first, then from the router you session to the switch module.
12-19-2011 03:38 PM
That is correct. Once you assign this IP then you can session to the switch module by using service-module GigabitEthernet 1/0 session
12-19-2011 03:16 PM
12-19-2011 03:25 PM
Ah yes - I recall that now. Something like "service-module GigabitEthernet 1/0 session". Thank you.
12-19-2011 03:30 PM
You got it. Don't forget to assign an IP address first, if not it will not let you session in to the switch module.
I don't remember the exact interface, but you will know when you login. As soon as you assign an IP to it the interface comes up.
12-19-2011 03:33 PM
So in this case - adding an IP to the Gig 1/0 - right? e.g.
interface GigabitEthernet1/0
description Int to Access Service-Module
ip address 192.168.253.254 255.255.255.252
12-19-2011 03:38 PM
12-19-2011 03:42 PM
Again - thank you very much.
12-19-2011 03:56 PM
Good luck and thanks for the rating!
