Community Member
POE failed on NME-16ES-1G-P, need to configure
We are getting a replacement NME-16ES module shortly.  I don't see a console port on these pups.  Once installed - how can we add the configuration from the failed NME-16ES?  It's been a couple of years since I initiall set these up.  Thank you.
2 ACCEPTED SOLUTIONS
VIP Super Bronze
This is module that gets inserted into a 2900, 3900, etc...  There is no console port.  You login to the router first, then from the router you session to the switch module.
VIP Super Bronze
That is correct. Once you assign this IP then you can session to the switch module by using service-module GigabitEthernet 1/0 session
VIP Super Bronze
Community Member
Ah yes - I recall that now.  Something like "service-module GigabitEthernet 1/0 session".  Thank you.
VIP Super Bronze
You got it.  Don't forget to assign an IP address first, if not it will not let you session in to the switch module.
I don't remember the exact interface, but you will know when you login.  As soon as you assign an IP to it the interface comes up.
Community Member
So in this case - adding an IP to the Gig 1/0 - right?  e.g.
interface GigabitEthernet1/0
description Int to Access Service-Module
ip address 192.168.253.254 255.255.255.252
VIP Super Bronze
Community Member
Again - thank you very much.
VIP Super Bronze
Good luck and thanks for the rating!
723
