PoE Issues on 3550 series
I need to understand this output>>> %C6K_POWER-1-PD_HW_FAULTY: There's a hardware problem on port [dec]/[dec]. Power is turned off on the port. <<<
Does this mean that the issue is with the switch port hardware or the Ip Phone hardware?
Re: PoE Issues on 3550 series
I had this message and TAC replaced the hardware
you mean you replaced the switch port hardware
Check out the below link for explanation on the mentioned error :-
https://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/power_over_ethernet.html
Hope to Help !!
Ganesh.H
417
