POE not aware devices X Cat6 X POE switch 1000T
We are considering change our switches.
This is the scenario:
- Small network, about 80 ports (currently with some 3com and Cisco 100TX switches connected by uplinks)
- Cat6 (yes six) all over the network
- Printers/Desktops/Notebooks/etc... connected
We are thinking about the WS-3750G-48PS-S model, because in near future we may need POE.
So we have some few basic questions:
1-) Will the switch work with devices that are not aware of POE or will them get fried?
2-) Is the cabling ok for that?
3-) May I put one new 3750 and keep the old switches connected by uplinks to it? Keep in mind that those switches are also not POE aware.
4-) Will gigabit ethernet run on devices that have this option?
5-) Will it be just plug and play or will we need to do a lot of configurations?
Thanks for any help you can give.
Marlon
1 REPLY
Re: POE not aware devices X Cat6 X POE switch 1000T
double post, check section "getting started".
149
