Community Member
PoE on catalyst 3750
i am trying to use PoE feature on cisco catalyst 3750 with IP Base image but it seems not supported, is there any image recommended for that ?
Mustapha Bensalah
Re: PoE on catalyst 3750
It all depends on the 3750 model that you have. Not all 3750 models support POE. Here is a good link for you to verify your switch model and see if your model supports POE.
http://www.cisco.com/en/US/products/hw/switches/ps5023/index.html
Community Member
many thanx !
Bronze
PoE is not a software feature. What's the model of your switch as listed in your sh ver?
Purple
I think it says POE on the front of the box if it is POE , at least the 3560's do .
181
