PoE on IE-3000-4TC?
I am setting up the Cisco IE-3000-4TC with a PWR-IE65W-PC-AC= power supply connected to Power A feed. Switch is running IOS 15.0(2)EY2. Does this provide PoE on the 4 fast ethernet ports of the IE-3000-3TC or do I need the Cisco IEM-3000-4PC= expansion module?
If I need the expansion module do I also need another PWR-IE65W-PC-AC= power supply?
Everyone's tags (2)
Hall of Fame Super Gold
PoE on IE-3000-4TC?
I don't think IE swtiches can do PoE.
Hello, Yes IE switches can do
Yes IE switches can do PoE.
You can choose either IE2000, IE3000 and or new switch the IE4000. Regarding the specific model to do PoE, it is referenced in their respective data sheets.
To Richard's Question - you will need to use one PSU per PoE Module - Yes.
Moriani, Thank you
Moriani,
Thank you
PoE on IE-3000-4TC?
For future reference, you will need to either use the following modules for the IE3000:
i. IEM-3000-4PC
ii. IEM-3000-4PC-4TC
and yes you will need to use a separate 65W power supply for the module.
For further details, please refer to page 2-23 in the hardware installation guide located here:
http://www.cisco.com/en/US/docs/switches/lan/cisco_ie3000/hardware/installation/guide/ie3000_higr.pdf
A follow up question:If I
If I have 2 of the IEM-3000-4PC modules, do I need 2 PWR-IE65W-PC-AC= or -DC= units?
625
