POE problem on a WS-X4548-GB-RJ45V line card in a 4510
Group.
I have a recent problem in which the slot will not send out the initial voltage to each port. I have working phones with PCs attaching working at the moment but it seems as if they're dropping off one by one. I'm able to plug a PC into the port and it works just fine, so i know it's a PoE issue but i'm not sure what the cause is. In order to fix this i have been moving users to another slot on the chassis. This is quickly becoming a capacity issue since we're using CER as well. Has anyone else seen this type of issue on these line cards?
fix?
Hall of Fame Super Silver
Re: POE problem on a WS-X4548-GB-RJ45V line card in a 4510
Hello Mike,
do you see any log messages for POE events in the switch ?
what you see in
sh power output ?
If I remember correctly we had to replace a linecard of this model two mounths ago on a C4506 for the same reason.
Hope to help
Giuseppe
There hasn't been any recorded events in the logs.
Here are the inline totals for that module.
Totals: 24 on 343.6 305.8
We have 24 working and prob 10 ports have been moved off. I'm thinking of just replacing the slot as well.
683
