Webcast-Catalyst9k
PoE switch with Routing capablities
I am looking for a PoE switch with Routing capablilites (e.g osfp) something lower end than 3560E.
1 ACCEPTED SOLUTION
Silver
E stands for enhanced image---IP services
S- standarad image---IP base
L- LAN Base
you need IP services image to enable full routing (OSPF in your case), you can find the comparisons at the below link
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-579326.html
c3560X-24-S-E----- IP Base to IP Services Cisco IOS Software Upgrade
c3560X-24-L-E------LAN Base to IP Services Cisco IOS Software Upgrade
you can buy a  WS-C3560X-24P-E (means factory upgrade to Enhanced image) .
Siddhartha
Silver
You can go with a WS-C3560X-48P-E (IP services image), it will cost you aprox $8000 based on your discount
Siddhartha
Thank you for the feedback. Is there 24 port model, I am not sure about the difference c3560X-24-S-E and c3560X-24-L-E
Silver
L- LAN Base
Siddhartha
Thank you so much for your help.
Hall of Fame Super Gold
And you are sure you only want PoE and not PoE plus, is this correct?
We need the switch to be able to support VOIP. What is the difference between the two.
PoE will support up to 15.4w.
PoE+ will support up to 30.0w.
uPoE (universal PoE) will support up to 60.0w
Silver
PoE would be enough for VoIP, you would need PoE+ for some accesspoints, I am not sure about UPoE
Siddhartha
Would the WS-C3560X-24P-E support an accesspoint also like cisco LAP-1142n.
Yes.
387
