Community Member
police xxxx exceed-action drop is not avilabe under policymap??!!!!
hi ,
im using qos
here is my config
class-map match-all wireless
match access-group name wireless
policy-map wireless
class wireless
  bandwidth 15000
class class-default
  fair-queue
as u see, im using qos to gurantee 15 mega for users of the access-list wireless
in the same time i want the traffic not to exceed 16 mega ,
i just want to give 15 gurantee , and  up to 16  if aviable
im trying to type the command
police 160000 exceed-action drop
but the ios is not accepting it ,
im wondering  how to  type it and limit the bw up to 16 mega ???
here is the outut when i try to type it
Gateway2(config-pmap-c)#police 16000 ?
  <500-512000000>  Burst bytes
  bc               Conform burst
  conform-action   action when rate is less than conform burst
  pir              Peak Information Rate
  <cr>
as u see there is no exceed-action but instead , there is
conform-action
regards
Everyone's tags (4)
1 ACCEPTED SOLUTION
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a00807f3f8d.html#wp1297330
here you can find full examples for the 7600 series.
Please rate if you believe i have been helpful
Alessio
policy conform-action transmit exceed-action drop...
conform first!
Alessio
Community Member
hi ,
should i type the command
police 15000 conform-action transmit  exceed-action drop
or
police 16000 conform-action transmit  exceed-action drop
i just want to gurantee 15 , and give upto 16 if avaibale
regards
Highlighted
Under your police command, specify a conform action and then your exceed action should be available.
HTH,
John
HTH, John *** Please rate all useful posts ***
Community Member
hi ,  wt should i give a value to confim action ?
should i give it the gurantee bw ???
in this case , does the command bandwith  id needed ??
regards
Community Member
Hi Ahmed,
please do not mix garanteed bandwidth with policing.
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_n1.html#wp1047146
Please read the usage of this command aand especially the usage guidelines in this doc.
Alessio
Community Member
hi ,
after all of that ,
the command is not being accepted
bandwidth command is not supported in input direction for this interface
Gateway2(config-if)#service-policy output  wireless
bandwidth command is not supported in output direction for this interface
Configuration failed on GigabitEthernet1/1
*Jul 24 11:18:45.650: %QOS-6-POLICY_INST_FAILED:
Service policy installation failed
Gateway2(config-if)#service-policy input  wireless
neither output nor input !!!!!!!!!!
i guess you nee to remove the bandwidth command first. and then to re-apply it in the direction you need
send the qos/interface config if you can
Alessio
Community Member
hi ,
i removed the bandwith command
and again another problem
Gateway2(config-if)#service-policy  output wirless
% policy map wirless not configured
fair-queue command is not supported in output direction for this interface
Configuration failed on GigabitEthernet1/9
$$$$$$$$$$$$$$$$$$$$$$$4
my ios is
"sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
my router is 7640
im wondering if my router accept QOS ??????/
regards
Community Member
the config is so simple
policy-map wireless
class wireless
class class-default
  fair-queue
ip access-list extended wireless
permit ip xx.xx.66.128 0.0.0.127 any
regards
Yes,
i think that you need to take away fair-queue and to leave the default FIFO on class-default.
Alessio
Community Member
it accepted it after removing fair queue
but now , im wondering ,
i removed fair queue and bandwith commands , and asking if the qos has  benefit ????
i mean  wt should i do to gurantee 15 mega bw for the acceslist wireless ??????
regrads
Community Member
hi , i  made another policaymap and the same issue appeared !!!
here is new config
class-map match-all AlessioAndreoli
policy-map AlessioAndreoli
class AlessioAndreoli
  bandwidth 15000
and here is the output :
Gateway2(config-if)#service-policy output AlessioAndreoli
Gateway2(config-if)#service-policy input  AlessioAndreoli
as you see, it cant be applied niether in nor out
!!!!!!!!!!!!!!!!!!!!11
Community Member
hi ,
assume im not expert in policying and qos and that what i am.
i just want to gurentee 15  meg for  the access-list users , and dont want them to exceed any  more bandwih
my goal is to "" Gurantee bw , Dont allow exceed this bw""""
now ,
forget qos and policying
now wt i need to do in config  to achive my goal ??
could u give me a breif config of wt i need .
regards
Alessio
Community Member
hi ,
i found the command
police cir 2000000000 bc 62500000 be 62500000 conform-action
is  wt i want ,  and the cir  will be as bw gurantee
in the same thing , my  ios accepted the command using the police command
so il will use police command instead
thanks for guide
regards
HI Ahmed,
you need to better define wha you want to do. If you want policing then this is going to happen. If you want QoS benefit and remarking before policing this is not going to happen. Let me suggest you to check the difference betwen policing and shaping and to study the hierarchical shaping in CBWFQ.
With these topics on your mind you will definitely achieve what you want.
Alessio
2112
