Community Member
police xxxx exceed-action drop is not avilabe under policymap??!!!!
hi ,
im using qos
here is my config
class-map match-all wireless
match access-group name wireless
policy-map wireless
class wireless
  bandwidth 15000
class class-default
  fair-queue
as u see, im using qos to gurantee 15 mega for users of the access-list wireless
in the same time i want the traffic not to exceed 16 mega ,
i just want to give 15 gurantee , and  up to 16  if aviable
im trying to type the command
police 160000 exceed-action drop
but the ios is not accepting it ,
im wondering  how to  type it and limit the bw up to 16 mega ???
here is the outut when i try to type it
Gateway2(config-pmap-c)#police 16000 ?
  <500-512000000>  Burst bytes
  bc               Conform burst
  conform-action   action when rate is less than conform burst
  pir              Peak Information Rate
  <cr>
as u see there is no exceed-action but instead , there is
conform-action
regards
Everyone's tags (4)
1 ACCEPTED SOLUTION
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a00807f3f8d.html#wp1297330
here you can find full examples for the 7600 series.
Please rate if you believe i have been helpful
Alessio
policy conform-action transmit exceed-action drop...
conform first!
Alessio
Community Member
hi ,
should i type the command
police 15000 conform-action transmit  exceed-action drop
or
police 16000 conform-action transmit  exceed-action drop
i just want to gurantee 15 , and give upto 16 if avaibale
regards
Under your police command, specify a conform action and then your exceed action should be available.
HTH,
John
HTH, John *** Please rate all useful posts ***
Community Member
hi ,  wt should i give a value to confim action ?
should i give it the gurantee bw ???
in this case , does the command bandwith  id needed ??
regards
Community Member
Hi Ahmed,
please do not mix garanteed bandwidth with policing.
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_n1.html#wp1047146
Please read the usage of this command aand especially the usage guidelines in this doc.
Alessio
Community Member
hi ,
after all of that ,
the command is not being accepted
bandwidth command is not supported in input direction for this interface
Gateway2(config-if)#service-policy output  wireless
bandwidth command is not supported in output direction for this interface
Configuration failed on GigabitEthernet1/1
*Jul 24 11:18:45.650: %QOS-6-POLICY_INST_FAILED:
Service policy installation failed
Gateway2(config-if)#service-policy input  wireless
neither output nor input !!!!!!!!!!
i guess you nee to remove the bandwidth command first. and then to re-apply it in the direction you need
send the qos/interface config if you can
Alessio
Community Member
hi ,
i removed the bandwith command
and again another problem
Gateway2(config-if)#service-policy  output wirless
% policy map wirless not configured
fair-queue command is not supported in output direction for this interface
Configuration failed on GigabitEthernet1/9
$$$$$$$$$$$$$$$$$$$$$$$4
my ios is
"sup-bootdisk:c7600s3223-adventerprisek9-mz.152-1.S.bin"
my router is 7640
im wondering if my router accept QOS ??????/
regards
Community Member
the config is so simple
policy-map wireless
class wireless
class class-default
  fair-queue
ip access-list extended wireless
permit ip xx.xx.66.128 0.0.0.127 any
regards
Yes,
i think that you need to take away fair-queue and to leave the default FIFO on class-default.
Alessio
Community Member
it accepted it after removing fair queue
but now , im wondering ,
i removed fair queue and bandwith commands , and asking if the qos has  benefit ????
i mean  wt should i do to gurantee 15 mega bw for the acceslist wireless ??????
regrads
Community Member
hi , i  made another policaymap and the same issue appeared !!!
here is new config
class-map match-all AlessioAndreoli
policy-map AlessioAndreoli
class AlessioAndreoli
  bandwidth 15000
and here is the output :
Gateway2(config-if)#service-policy output AlessioAndreoli
Gateway2(config-if)#service-policy input  AlessioAndreoli
as you see, it cant be applied niether in nor out
!!!!!!!!!!!!!!!!!!!!11
Highlighted
Community Member
hi ,
assume im not expert in policying and qos and that what i am.
i just want to gurentee 15  meg for  the access-list users , and dont want them to exceed any  more bandwih
my goal is to "" Gurantee bw , Dont allow exceed this bw""""
now ,
forget qos and policying
now wt i need to do in config  to achive my goal ??
could u give me a breif config of wt i need .
regards
2176
