POLICY BASE ROUTING
suhas_syndrome
Hi experts,
  • •1)      I have configured 4 VLANS on my L3 switch.
  • •2)       I have one router which has connected 2 ISP link
  • •3)      L3 switch & router has connected each other through L3 link.(which has different subnet)
  • •4)      VLANS on L3 switch ( vlan10 , vlan20, vlan30, vlan40 ) each vlan has 24bit subnet
  • •5)      I want to pass vlan 10 , 20 through ISP1 & vlan 30, 40 through ISP2
  • •6)      If  anyone ISP  link fail all VLANS should be carried through remaining backup link
  • •7)      Please find the topology below
Please Assist..
8 Replies 8
Oleg Volkov
You must use IP SLA and route map.
You need check availability and chenge next-hop
As example, in route map:
set ip next-hop verify-availability  10 track XXX
set ip next-hop verify-availability 20 track YYY
And add route map on interface or SVI
Helping seriously ill children, all together. All information about this, is posted on my blog
Dear Oleg,
  I have done that all things which have you mentioned. but my question is what access-list should be created for vlans to send them L3 switch to router. Otherwise how could be the router send vlan 10, 20  through ISP1 & vlan 30, 40 through ISP2...
Suhas
Example:
We have two VLAN at catalyst:
one - 192.168.1.0/24
two - 192.168.2.0/24
Outside interfaces
(in my example, it is two subinterfaces)
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 172.16.4.112 255.255.255.0
ip nat outside
ip virtual-reassembly
no snmp trap link-status
Gateway for this interface is 172.16.4.1
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 192.168.55.210 255.255.255.0
ip nat outside
Gateway for this interface is 192.168.55.1
interface GigabitEthernet0/1
ip address 192.168.33.1 255.255.255.252
ip nat inside
ip policy route-map VLANWEB
duplex auto
speed auto
It is interface to catalyst
route-map NATR1 permit 10
match ip address NATACL
match interface GigabitEthernet0/0.1
route-map NATR2 permit 10
match interface GigabitEthernet0/0.2
route-map VLANWEB permit 10
match ip address VLAN1ACL
set ip next-hop 192.168.55.1
route-map VLANWEB permit 20
match ip address VLAN2ACL
set ip next-hop 172.16.4.1
ip access-list extended NATACL
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.2.0 0.0.0.255 any
ip access-list extended VLAN1ACL
ip access-list extended VLAN2ACL
ip nat inside source route-map NATR1 interface GigabitEthernet0/0.1 overload
ip nat inside source route-map NATR2 interface GigabitEthernet0/0.2 overload
ip route 192.168.1.0 255.255.255.0 192.168.33.2
ip route 192.168.2.0 255.255.255.0 192.168.33.2
Example debug out
*Aug  9 20:51:27.439: NAT*: s=192.168.2.18->172.16.4.112, d=8.8.8.8 [3643]
*Aug  9 20:53:21.899: NAT*: s=192.168.1.18->192.168.55.210, d=8.8.8.8 [4135]
But You need added in this example IP SLA tracker
And well be good if You, done this, public Your config in this forum
Thanks!
I modify config for support backup ISP
ip nat inside
ip nat outside
ip virtual-reassembly in
ip nat outside
ip sla 1
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0.1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0.2
ip sla schedule 2 life forever start-time now
track 123 ip sla 1 reachability
track 124 ip sla 2 reachability
ip access-list extended ISP1_SLA
permit icmp host 172.16.4.112 any
ip access-list extended ISP2_SLA
permit icmp host 192.168.55.210 any
route-map RMAP_SLA permit 10
match ip address ISP2_SLA
route-map RMAP_SLA permit 20
match ip address ISP1_SLA
ip local policy route-map RMAP_SLA
set ip next-hop verify-availability 192.168.55.1 10 track 124
set ip next-hop verify-availability 172.16.4.1 20 track 123
set ip next-hop verify-availability 172.16.4.1 10 track 123
set ip next-hop verify-availability 192.168.55.1 20 track 124
ip route 0.0.0.0 0.0.0.0 172.16.4.1 20 track 123
ip route 0.0.0.0 0.0.0.0 192.168.55.1 10 track 124
event manager applet ISPSW
event track 123 state any
action 1 cli command "enable"
action 2 cli command "clear ip nat trans forced"
event manager applet ISPSW2
event track 124 state any
Hi Oleg,
   What configuration should be done at L3 switch.
Suhas
At L3 switch You must have two SVI interfaces for each VLAN (IP ddress at this interfaces should be use as gateway for PC in this VLAN).
And You must set default route to Your router (ip route 0.0.0.0 0.0.0.0 xx.xx.xx.xx or ip default-gateway xx.xx.xx.xx (where xx.xx.xx.xx IP address of Your router)) and enable ip routing.
Dear Sandeep, in Your example, You do not use backup route patch for each VLAN
