Policy Based Routing on 6509
mccmhtac1
I need to setup my 6509 with PBR going to two different Firewalls. The 6509 has vlans and multiple serial interfaces. What/where do I install the policy-maps? I want to direct one of the vlans to one firewall and the other vlans and wan subnets to the other firewall.
26 Replies 26
pgurumu77
Use ACL or prefix list, apply the prefix list to the route-map, have set-interface option in route-map pointing to your vlan interface. If a packet matches your prefix-list or ACL the packet is directed to the interface specified in the route-map. WRT to where, depends on how you want to police your routes, based on what you are saying I would say on the interfaces. Under interface config you would see ip policy route-map "NAME"
Do you have any configuration examples?
Latchum Naidu
You need to apply the specific PBR under the specific VLAN which traffic you want to send through other firewall.
Make sure you used ip default next-hop command under the route-map.
Please rate the helpfull posts.
Naidu.
can you send any configuration examples?
Please find the below config what I have at one of my customer L3 switch. With this config the traffic will go from the specific network to the default next gateway which is 10.28.1.200
interface Vlan51
description MANAGEMENT NETWORK
ip address 10.246.2.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip policy route-map Net-access1
route-map Net-access1 permit 10
match ip address 171
set ip default next-hop 10.28.1.200
access-list 171 deny   ip 10.31.4.0 0.0.0.255 192.168.199.0 0.0.0.255
access-list 171 permit ip 10.31.6.0 0.0.0.255 any
access-list 171 permit ip 10.31.2.0 0.0.0.255 any
Hope the above helps you, if so please rate all the helpfull posts.
Naidu.
This does help, except I have a 6509 with multiple interfaces and vlans.
I am uncertain as to where (vlan/interfaces) to apply the router-map
policies.
As per the example config I provided in my last post.
You need to apply the route-map to which vlan traffic you want to send the specific firewall.
Still if you are not sure to where apply the route-map, post here your config so that I can advice you on that where to apply exactly.
Naidu.
Not sure if this is what you need, but here is the 6509 int and VLAN config.
The subnet (VLAN 30) 10.133.3.0/24 is to go to the UTM Firewall and all
traffic from the other serial connections as well the other VLANS are to
go to the IPSO firewall. Thank you.
interface Serial9/0/0:0
description Training Office DHZA802177
ip address 100.0.10.1 255.255.255.252
ip access-group 122 out
no fair-queue
interface Serial9/0/1:0
description Ventures DHZA845048
ip address 100.0.4.1 255.255.255.252
no fair-queue
interface Serial9/0/2:0
description FOCUS DHZA748373
ip address 10.15.0.58 255.255.255.252
no fair-queue
interface Serial9/0/3:0
description FN Multilink 1 dhza005310
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial9/0/4:0
description FN Multilink 2 dhza005311
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial9/0/5:0
description FSW Multilink 1 dhza005331
no ip address
encapsulation ppp
ppp multilink
multilink-group 2
interface Serial9/0/6:0
description FN Multilink 3 dhza005313
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial9/0/7:0
description FSW Multilink 2 dhza005309
no ip address
encapsulation ppp
ppp multilink
multilink-group 2
interface Vlan1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no mop enabled
interface Vlan10
description Phone network
ip address 10.133.1.1 255.255.255.0
arp timeout 240
interface Vlan20
description User network
ip address 10.133.2.1 255.255.255.0
arp timeout 240
interface Vlan30
description Server network
ip address 10.133.3.1 255.255.255.0
arp timeout 240
interface Vlan100
description Wireless network
ip address 100.1.200.1 255.255.255.252
interface Vlan101
description UTM1 Firewall
ip address 100.1.100.1 255.255.255.248
interface Vlan102
description IPSO Firewall
ip address 200.1.200.1 255.255.255.252
interface Vlan200
description AT&T OPTEMAN
ip address 10.10.10.1 255.255.255.248
interface Vlan300
description Aerohive WLAN
ip address 172.30.1.1 255.255.255.0
I would opt to define a default route towards the IPSO firewall (it will handle all other vlans and serial connections), and then use PBR for your exception of directing traffic from 10.133.3.0/24 to the UTM firewall.  I'm no expert on PBR, but I would try this config:
! default route towards the IPSO fw
ip route 0.0.0.0 0.0.0.0 200.1.200.2
interface Vlan30
ip policy route-map UTMPBRroute
access-list 100 permit ip 10.133.3.0 0.0.0.255
route-map UTMPBRroute permit 10
match ip address 100
set ip default next-hop 100.1.100.
-Jason
I tried this config and am still having problems:
I applied your config as follows:
FW1 - 100.1.100.2
FW2 - 200.1.200.2
Want 10.133.3.0/24 subnet to go to FW2 for internet usage
Want all other subnets to go through FW1 for internet
Gateway of last resort on core router: 0.0.0.0 0.0.0.0 100.1.100.2
ip access-list extended 150
permit ip 10.133.3.0 0.0.0.255 any
route-map TO-UTM1-FW
match ip address 150
set ip next-hop 200.1.200.2
Int Vlan30
ip policy route-map TO-UTM1-FW
When I do this I cannot access the servers on 10.133.3.0/24 subnet from
any other subnet. This is a problem
as all the other subnets need to access them as well.
Why don't you do this.
   deny ip 10.133.3.0 0.0.0.255
The reason without knowing everything about our internal network, is because of TTL expiration of IP packets as it bounces between your router and firewall.
Traceroute of you reaching out to your other private subnet from 10.133.3.0 to your internal network would help debug this issue little bit more better in my opinion.
Hope this helps!
If I deny from 10.133.3.0 to my internal network(s), then no one will
get to any services. See 10.133.3.0 is our server network. I want to
segregate it's internet usage to a separate firewall.
There are about 15 other subets that need to access 10.133.3.0 internally.
Remember this is an ACL applied to route-map, not to access-group, so deny on the ACL that is applied to the route-map means, when the packet is destined to internet the next hop is your "FW2", when it is your Internal, the next hop is what ever is in your routing table, not what is given in the route-map
I only have one default route on the core router to FW1 100.1.100.2. Do
I need to add another to FW2? seemed when it was in place, it affected
all the subnets.
