Community Member
Policy Based routing
Hi All;
I want to implement policy based routing in 871 router i have 2 dsl connections and both are connected to dsl modems 1 modem is performing natting to private ip and it is connecet to switch port of 871
Other DSL is connected to WAN port of 871
now what i want to do is to use both ISP for load sharing i want routing in such a way that if the requested ip is 202.x.x.x than it passes through my 2nd IP having private ip and connected to switch port
1 REPLY
Re: Policy Based routing
Pls provide the config of your 871 router.
regards
vanesh k
136
