Community Member
Policy Routing on Catalyst 3560
PBR is configured on a Cisco Catalyst 3560 Switch.
The Switch is running with c3560-ipservices-mz.122-25.SEE2/c3560-ipservices-mz.122-25.SEE2.bin" Image. However while applying the PBR on the vlan interface, though it takes the command.
However the command doesn't get applied on the vlan interface ( show running)
Does SDM prefer routing command will resolve the problem or is there any other solution.
Re: Policy Routing on Catalyst 3560
Your IOS supports PBR as per the Cisco feature navigator, and thus it should work, have you "ip routing" configured.
HTH,
Mohammed Mahmoud.
Community Member
Yes already ip routing is configured.
I think you would require the SDM prefer routinmg command to use policy routing
Narayan
310
