Webcast-Catalyst9k
port bandwidth monitoring on cisco switches
Hi to all,
1.How to monitor one or more port's bandwidth on daily basis in cisco switch or router.
2. How to check the cpu usage and memory usage in cisco switch or router
3. Any tools available with cisco..
Pls reply
Re: port bandwidth monitoring on cisco switches
MRTG or Cacti - I prefer Cacti.
Below is the link for a self build linux ISO for a system that will do all you want and more:-0
http://cactiusers.org/wiki/CactiEZ
HTH>
hi prince,
Thanks for your recommendation let me try cacti and reply back.
Thanks again....
try using solarwinds. they have this 30 days trial on their orion network performance monitor and other tools. avail it if your company has a budget. we use it and it's worth it!
1922
