10-05-2013 07:29 PM - edited 03-07-2019 03:51 PM
Can someone help me understand how the switch port behaves when a port is configured for access port as well as trunk port.
int gi1/3
Switchport
switchport access vlan XX
switchport mode trunk
Switchport trunk enca dot1q
switchport trunk allowed vlan YY,ZZ
If the trunk fails for any reason will the port will changes its behavior to access port? In the above configs the command mode trunk will override the behavior of access port to trunk port , and to my knowledge unless you change mode “no switchport mode trunk" we cannot change the behavior of the port to access mode. let me know if my understanding is correct or not.
10-05-2013 09:09 PM
You can't have a single port act as an access port AND a trunk port. You can only have one. The configuration line which determines which is which is "switch port mode trunk" or "switch port access vlan XX".
Sent from Cisco Technical Support Nintendo App
10-05-2013 09:41 PM
Thanks for your reply, I understand the port cannot be BOTH,That's what I mentioned in my post as well.my question was "If we have both configs and if the trunk fails for any reason will the port changes its behavior to access port automatically ??" with out human intervetion or with out converting port back to access port by using the command no switchport mode trunk
10-06-2013 08:33 AM
As Leo stated, your mode is strictly configured for a trunk which means that you won't be able to fail over to an access port. You can however have the port configured for dynamic which will try to form a trunk. If that fails, then it will fall over to an access port on the vlan that you have configured on the port.
HTH,
John
*** Please rate all useful posts ***
10-06-2013 06:00 PM
Hi.
To keep it simple: the answer is NO!!!
The best you can do configure the port as dynamic desirable.
Switch(config-if)#switch mode dynamic desirable
Regards.
Wilson B.
10-08-2013 06:43 AM
This is needed when DTP (Dynamic Trunk Protocol) is active.
Suppose you do not have "switchport mode runk", then DTP will try
to negotiate with the other device if the interface is "access" or "trunk".
This negotiation take about 2 sec.
Because I think this is very dangerous, I allways configure the
some "switchport mode ..." an in addition
"switchport nonegotiate" in order to disable DTP.
Then the DTP do not loose 2" to negotiate nothing.
