Community Member
Port Channel 2960 Stack to 4500X VSS Stack
I have a stack of three 2960s using stack wise cables to make them into one logical switch.  I have two 4500x switches stacked via VSS.
The 2960 top switch will be trunked to the 4500x top switch and the 2960 bottom switch will be trunked to the 4500x bottom switch.
Is it required that I port channel the trunk ports on each stack?  If I don't port channel these ports, will it be a basic STP block on one port?  Is it recommened that I port channel these ports?
Thanks for your help
Hey,You may or may not
Hey,
You may or may not configure port-channel these links depending on your requirements.
If you don't bundle them then STP will block the alternate link, however its recommended to have port-channel as you will be able to utilize the bandwidth available of other link.
HTH.
RS.
Community Member
Thank you rajeevsh.  Is there
Thank you rajeevsh.  Is there an added risk to utilizing the port-channel configuration compared to relying on STP?
None, so go for etherchannel
None, so go for etherchannel :)
HTH.
RS.
Community Member
Rajeevsh, If we don't want to
Rajeevsh,
If we don't want to rely on etherchannel hello negotitations between stacks, do you recommend we use the "on" mode?  This will give us more manual control?
Hey,Surely you may use ON
Hey,
Surely you may use ON mode as it will not use the negotiation used by ether-channel protocols.
RS.
Community Member
rajeevsh,We are cuurently
rajeevsh,
We are cuurently using a Cisco phone system.  We setup auto qos on the switch ports including the uplink trunk ports.  When we setup auto qos voip trust on the uplink trunk port while the port is a member of a port channel, it does not let us.  We have to apply the auto qos voip trust beforeewe add the port to a port channel.  Will the port still honor the voip qos when it is a member of the port channel?  Below is the configuration.
interface TenGigabitEthernet1/0/1
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
auto qos trust
channel-group 2 mode on
Yes it will honor the voip
Yes it will honor the voip qos even after bundling in port-channel. For reference i am adding snippet from my switch:
WS-C3750V2-48PS-1#sh run int f1/0/36
Building configuration...
Current configuration : 167 bytes
interface FastEthernet1/0/36
 srr-queue bandwidth share 10 10 60 20
 priority-queue out
 mls qos trust cos
 auto qos voip trust
 channel-group 1 mode passive
end
WS-C3750V2-48PS-1#sh mls qos interface f1/0/36
FastEthernet1/0/36
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
HTH.
RS.
Community Member
One last thing that confused
One last thing that confused us is that when we enter "auto qos voip trust" to the uplink/trunk interface, it changes it to "auto qos trust" when we view the running config.  Do you know why this happens?  is it the same thing?
782
