Port channel btw 3550 and 3560
I have a 3550 ans 3560 switches connected together over three link, so I configured switch port mode to be desirable on the 3560 and switch port mode auto on the 3550. they trunk normaly, but when i configure portchannel like the config below, they port chanel never come up
3560................
interface Port-channel14
switchport mode dynamic desirable
nterface FastEthernet0/19
channel-group 14 mode on
interface FastEthernet0/20
interface FastEthernet0/21
3560(config-if)#do sh ethe summ
14     Po14(SD)         -        Fa0/19(D)   Fa0/20(D)   Fa0/21(D)
3550..................
switchport mode dynamic auto
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
3550(config-if-range)#do sh ether summ
14     Po14(SD)         -        Fa0/13(D)   Fa0/14(D)   Fa0/15(D)
VIP Super Bronze
Re: Port channel btw 3550 and 3560
change "channel-group 14 mode on" to
"channel-group 14 mode desirable" and test again.
Reza
Silver
Are the physical interfaces up? I know it´s a stupid question but since you have "channel-group 14 mode on" on the interfaces should come up as standalone (I) or suspended (s) in case of a channel misconfig
Changing the channel-group  mode to desirable means using Pagp, I want to use same config.
840
