Webcast-Catalyst9k
port channel failure / lacp_switch_get_new_agg_id: secondary l3 agg are not supported
hi,
hope that someone can help.
I ran into port channel issue when trying to add 4 port Quantum Dxi server into a port channel in 3750 stack.
Configs looks ok:
interface Port-channel6
description qdx-server
switchport access vlan 3
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
end
all four ports configured as follows
interface GigabitEthernet1/0/7 , 1/0/5 , 2/0/7 and 2/0/8
description qdx-server-ethx
channel-protocol lacp
channel-group 6 mode active
end
all ports joined the channel except Gi 1/0/5 - it got suspended once joined the port channel
From the debug I got the following:
Dec 16 13:36:43.082 GMT: FEC: lacp_switch_get_new_agg_id: secondary l3 agg are not supported Po6
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_agc_compatable: comparing GC values of Gi1/0/5 Gi1/0/7 flag = 1 1
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_port_attrib_diff: compare LACP modes for Gi1/0/5
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_port_attrib_diff: Gi1/0/5 Gi1/0/7 same
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_agc_compatable: GC values are compatable
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_restart_if_needed(1): Gi1/0/5 in list
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_invoke_port_down: Gi1/0/5
Dec 16 13:36:46.823 GMT: FEC: pagp_switch_invoke_port_up: Gi1/0/5
Dec 16 13:36:46.823 GMT: FEC: lacp_switch_calculate_oper_key: oper_key for port Gi1/0/5 is 0x6
Dec 16 13:36:46.982 GMT: FEC: lacp_switch_get_first_agg_id_from_admin_oper_keys: found aggregator Po6 for admin_key [0x6] and oper_key [0x6]
Dec 16 13:36:46.982 GMT: FEC: lacp_switch_is_aggregator_valid: aggregator Po6 is still valid
Dec 16 13:36:46.982 GMT: FEC: lacp_switch_get_first_associated_port_from_agg_id: found port Gi2/0/8 associated to Po6
Dec 16 13:36:46.982 GMT: FEC: lacp_switch_get_next_agg_id_from_admin_oper_keys: aggregator next to Po6 not found for admin_key [0x6] and oper_key [0x6]
Dec 16 13:36:46.982 GMT: FEC: lacp_switch_get_new_agg_id: secondary l3 agg are not supported Po6
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_agc_compatable: comparing GC values of Gi1/0/5 Gi1/0/7 flag = 1 1
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_port_attrib_diff: compare LACP modes for Gi1/0/5
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_port_attrib_diff: Gi1/0/5 Gi1/0/7 same
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_agc_compatable: GC values are compatable
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_restart_if_needed(1): Gi1/0/5 in list
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_invoke_port_down: Gi1/0/5
Dec 16 13:36:56.830 GMT: FEC: pagp_switch_invoke_port_up: Gi1/0/5
Dec 16 13:36:56.838 GMT: FEC: lacp_switch_calculate_oper_key: oper_key for port Gi1/0/5 is 0x6
Dec 16 13:36:56.880 GMT: FEC: lacp_switch_get_first_agg_id_from_admin_oper_keys: found aggregator Po6 for admin_key [0x6] and oper_key [0x6]
Dec 16 13:36:56.880 GMT: FEC: lacp_switch_is_aggregator_valid: aggregator Po6 is still valid
Dec 16 13:36:56.880 GMT: FEC: lacp_switch_get_first_associated_port_from_agg_id: found port Gi2/0/8 associated to Po6
Dec 16 13:36:56.880 GMT: FEC: lacp_switch_get_next_agg_id_from_admin_oper_keys: aggregator next to Po6 not found for admin_key [0x6] and oper_key [0x6]
Dec 16 13:36:56.880 GMT: FEC: lacp_switch_get_new_agg_id: secondary l3 agg are not supported Po6
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_agc_compatable: comparing GC values of Gi1/0/5 Gi1/0/7 flag = 1 1
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_port_attrib_diff: compare LACP modes for Gi1/0/5
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_port_attrib_diff: Gi1/0/5 Gi1/0/7 same
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_agc_compatable: GC values are compatable
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_restart_if_needed(1): Gi1/0/5 in list
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_invoke_port_down: Gi1/0/5
Dec 16 13:37:06.837 GMT: FEC: pagp_switch_invoke_port_up: Gi1/0/5
Dec 16 13:37:06.837 GMT: FEC: lacp_switch_calculate_oper_key: oper_key for port Gi1/0/5 is 0x6
Dec 16 13:37:07.080 GMT: FEC: lacp_switch_get_first_agg_id_from_admin_oper_keys: found aggregator Po6 for admin_key [0x6] and oper_key [0x6]
Dec 16 13:37:07.080 GMT: FEC: lacp_switch_is_aggregator_valid: aggregator Po6 is still valid
Checked and compared the config from another server, all looks OK.. I tried to search the error message in bold, but can't find any.
Can anyone shed a light?
Many thanks.
Everyone's tags (2)
we have the same issue with
we have the same issue with asa5525 and 3750E etherchannel.
The same error
lacp_switch_get_new_agg_id: secondary l3 agg are not supported on the SWITCH side
we are using LACP active from noth sides
I had the same issue running
I had the same issue running a firewall in Active-Active mode, what mode are you using ?
490
