02-26-2014 04:57 AM - edited 03-07-2019 06:24 PM
Im trying to create port channel between switch and WLC, port channel is up but 2nd link WLC and switch is not coming up.
Cable is fine and I can see link flaps error on WLC logs.
Any idea..
02-26-2014 05:27 AM
Could you post ethechannel config?
HTH,
Dragan
02-27-2014 09:47 AM
Hi ,
Do you use pagp port-channel ? if yes please try to use mode on in your port channel.
WLC probably does not support pagp.
Best...
03-01-2014 08:39 PM
We are using "on" mode, from switch side port channel is up with 1st link but 2nd link status is showing not connect.
When I check WLC, I can see 2nd link flaps error.We have also verified the cable connectivity
Am I missing anything.
03-01-2014 09:28 PM
Use Lacp because pagp isn't supported by most of WLC.
Check your cabling too.
03-01-2014 10:11 PM
Hi Farrukh,
We are not using PAGP, 2nd switchport is configured with On mode and cabling also verified.
1st link is working fine and channel is up but 2nd link is showing "not connect" and WLC is showing link flaps error which is confusing us
03-02-2014 02:50 AM
Use LACP port-channel and verify the console log from switch side.
