11-29-2007 10:10 AM - edited 03-05-2019 07:43 PM
I am setting up some port-channels and want to know how each end should be setup...
I created this on each end...
interface port-channel 2
switchport
switch mode trunk
no ip address
Then this on each of the two interfaces at each end that were added...
switchport
switch mode trunk
no ip address
channel-group 2 mode on
The question is should both ends of the channel-group say "mode on". Is this the right way to do this?
Solved! Go to Solution.
11-29-2007 10:20 AM
If both link partners are cisco devices, I recommend going with desirable/desirable or desirable/auto.
I went over this on another thread
11-29-2007 10:20 AM
11-29-2007 10:36 AM
If you follow the SRND Best Practise guidelines you should hard-code the Port-Channels (and VLAN trunks) as this decreases the time it takes for the interfaces to come up and converge:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns656/c649/cdccont_0900aecd804ab67d.pdf
It is quite significant as well - hard-coded Trunks gain you 2-seconds or so, hard-coded EtherChannels gain you as much as 7-seconds.
All the design guidelines are at the SRND site:
Andy
11-29-2007 10:49 AM
Andy,
That's one of those religious battles that I don't want to get into :)
Page 40 describes the topic at hand. Notice how the comparison is done with 'PAgP mismatch'. It never said 'not' to use PAgP.
There are a lot of features that you gain by using PAgP (I discussed this in the other thread) vs using ON.
11-29-2007 10:56 AM
Hi, Yes I have been through this before. I remember older best practise documents stating to use Desirable/Desirable etc, and I have put in networks using this. However I have done some testing in the lab and hard-coding trunks & channels does improve convergence time slightly. I also think it is good administrative practise to ensure all ports are configured specifically for their purpose and unused ports are shutdown and placed into a 'null' VLAN.
This all obviously goes wrong if someone decides to do some re-cabling but it would do either way anyway :o)
Andy
11-29-2007 11:03 AM
The option depends on the customer.
If they want the faster convergence time, the ON (as you stated) will provide that but it has a risk of going into etherchannel mode without checking the link partner.
Not sure if I want to implement a network where it doesn't have some kind of intelligence built-in.
I rather sacrifice the 1 or 2 seconds convergence time (BTW, I will have to check that with new IOS codes) vs misconfigured link-partners.
During my CCIE Lab preparation, I often used the 3 options and found no delay in convergence time...
11-29-2007 11:14 AM
For testing in the lab we used just two switches at Layer-2 and used HrPing utility on a PC. This was to verify the layer-2 link had come up and converged. Obviously in a structured network there are more elements to be considered like STP & routing protocols but for pure link up times it did improve with hard-coding things (trunks & channels).
I understand the potential issues that would arise if one end was accidentally reconfigured or a cable was re-patched incorrectly. This is all part of the administrative procedures though.
Andy
11-29-2007 11:53 AM
I myself don't like hardcoding them as more than once we have seen where if you hardcode a trunk really all it needs to see is a physical connection and it can say it is trunking when it really is not , if you let them negotiate the trunks and etherchannels we have not seen this problem .
