Port Counter Errors
In my Network is having 6509-E and 4006 on IOS and catos.couple of the interfaces/ports on Full Duplex with speed auto.
Pointing out the issue is with port counter errors facing ---> Alignment,FCS and Input errors are increasing the count.
how can i rectify this errors.
Thanks in advance!
Re: Port Counter Errors
Typically the errors you are seeing are related to a bad cable, or NIC. Please check the cables and make sure they haven't been mangled, or crimped improperly.... etc
Here is a good troubleshooting guide.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml
Mark
Thanks a lot!! Mark
Drill down the list?
might correct the errors
Purple
Check on each end of the link on these , the settings must match , if the speed and duplex is auto on one end then it must be auto on the other end , if hardcoded to say 100/full then the other end must be hardcoded also . If you are attaching 2 cisco devices then auto/auto should work fine .
131
