port err-disabled
hi,
i have problem with Switch 2960 TT . There is Port err-disabled and Link is down.when we do shut no shut just one up and again link is down . and port indicate err-disabled.??/ so what i will do ...>?
Re: port err-disabled
Reconnect the cable or replace it with a new one.
Wandering
What's connected to the switch port?
Hall of Fame Super Silver
Hello Jayesh,
first of all you need to understand why the port is placed in error-disable state.
You can use sh log to see last events related to that port or simply
term mon
int type x/y
shut
no shut
you should see the reason.
among possible reasons:
spanning-tree bpduguard
port security
receiving not correct STP information on a trunk port
Hope to help
Giuseppe
Hall of Fame Super Gold
Giuseppe's right. It is worthwhile to know WHY the port goes into repeatitive error-disable. Use the command sh intertace status err will give you a brief explanation.
Hope this helps.
181
