port fast and 3500 XL Switch
i got 2 3500 series XL switches for labing. I already know that I can't use int range for configs because of the old IOS 12-0-5.WC17, its actually the highest one that can run on it, memory limitations for higher IOS i gather.
Anyway, is there a way to add portfast to all access ports on this so i don't have to do it manually for all ports. Thanks
1 ACCEPTED SOLUTION
VIP Super Bronze
Re: port fast and 3500 XL Switch
There is no other way.  You have to do it one at the time for each interface since the interface range is not available
Reza
VIP Super Bronze
Reza
not even a global command or nothing, ok
VIP Super Bronze
VIP Super Bronze
yea i was gonna tell you it had both guard and filter but not default in global. defualt is the one im looking for. In order to use guard, portfast has to be enabled. I was hoping for a miracle to have better way of one by one int. IOS limitation confirmed, thanks anyway
608
