01-13-2014 09:51 PM - edited 03-07-2019 05:32 PM
I am trying to have my domain (jjkkcc.org) get directed to my server from my Cisco 1841. I have godaddy DNS configured to my static IP to my router, and I just want to make sure I have my router configured correctly so the WWW traffic is passed to my web server (192.168.1.250).
Cisco1841#show run
Building configuration...
Current configuration : 1715 bytes
version 12.4
hostname Cisco1841
boot-start-marker
boot system usbflash0:c1841-advipservicesk9-mz.124-12.bin
boot-end-marker
no aaa new-model
clock timezone PSD -8
ip cef
ip domain name jjkkcc.com
ip name-server 68.105.28.16
ip name-server 68.105.29.16
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 192.168.1.250
username woodjl1650 privilege 15 password 0 henry999
interface FastEthernet0/0
ip address 192.168.1.6 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 24.234.XXX.XXX 255.255.255.224
ip nat outside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 24.234.XXX.XXX
no ip http server
no ip http secure-server
ip nat inside source list NAT interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.250 80 interface FastEthernet0/1 80
ip nat inside source static tcp 192.168.1.10 3074 interface FastEthernet0/0 3074
ip nat inside source static udp 192.168.1.10 3074 interface FastEthernet0/0 3074
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255
ip access-list extended WEB
permit tcp any any eq www
snmp-server community public RW
snmp-server trap link ietf
snmp-server location Las Vegas, NV, USA
snmp-server contact Jonathan Wood - Network Admin
snmp-server chassis-id Cisco1841-Router
snmp-server host 192.168.1.155 version 2c public
control-plane
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
01-13-2014 10:04 PM
Port forwarding looks good.
Please rate replies and mark question as "answered" if applicable.
01-14-2014 03:41 AM
These two lines look incorrect because of the interface:
F0/0 is your lan interface. Wouldn't you want those attached to fa0/1?
HTH,
John
*** Please rate all useful posts ***
