Webcast-Catalyst9k
Port Forwarding Cisco 1841 issue
Good day,
I have a cisco 1841. I have not had any success in forwarding the following ports:
Fowrard UDP Port 1194 to 10.20.36.222
Forward TCP Port 4444 to  10.20.36.222
Router IP is 10.20.36.249
I'm using the CLI (but do have the SDM installed also)
The forwards don't see to 'stick' am I forgetting something else. Can someone post the correct syntax of the config command please..
See below a copy of running config.(some items removed for security reasons)
Warm regards
Current configuration : 5657 bytes
! Last configuration change at 09:33:42 EST Mon Oct 21 2013 by admin
! NVRAM config last updated at 09:47:43 EST Fri Oct 18 2013 by admin
version 12.4
boot-start-marker
boot system flash c1841-advsecurityk9-mz.124-21.bin
boot-end-marker
no logging buffered
enable secret 5 $1$I2Lg$NHGXwwc8c6b.0m9EWP37O1
no aaa new-model
clock timezone EST -5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp pool Guest
   network 192.168.123.0 255.255.255.0
   default-router 192.168.123.1
   dns-server 4.2.2.2 8.8.8.8
crypto pki trustpoint TP-self-signed-3275215788
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3275215788
revocation-check none
rsakeypair TP-self-signed-3275215788
  hidekeys
ip rcmd rcp-enable
ip rcmd remote-host sdmR3d89e8a9 10.20.36.135 L3d89e8a9 enable
interface FastEthernet0/0
ip address 10.20.36.249 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
no cdp enable
interface FastEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.123.1 255.255.255.0
ip nat inside
no ip route-cache
interface FastEthernet0/1
description $ETH-LAN$
ip nat outside
no ip route-cache
duplex auto
speed auto
interface Serial0/0/0
ip nat inside
encapsulation ppp
router eigrp 1
passive-interface FastEthernet0/0
passive-interface FastEthernet0/1
network 10.0.0.0
network 172.16.0.0
no auto-summary
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 71.43.32.105
ip route 10.209.0.0 255.255.0.0 10.20.36.254
ip route 10.247.208.0 255.255.255.0 10.20.36.222
ip route 12.171.243.0 255.255.255.0 10.20.36.254
ip route 12.171.244.0 255.255.255.0 10.20.36.254
ip route 12.171.245.0 255.255.255.0 10.20.36.254
ip route 12.171.246.0 255.255.255.0 10.20.36.254
ip route 12.171.247.0 255.255.255.0 10.20.36.254
ip route 63.90.86.0 255.255.255.0 10.20.36.254
ip route 69.60.80.0 255.255.255.0 10.20.36.254
ip route 69.60.81.0 255.255.255.0 10.20.36.254
ip route 69.60.83.0 255.255.255.0 10.20.36.254
ip route 69.60.84.0 255.255.255.0 10.20.36.254
ip route 69.60.85.0 255.255.255.0 10.20.36.254
ip route 142.30.0.0 255.255.0.0 10.20.36.254
ip route 172.16.0.0 255.255.255.0 10.20.36.222
ip route 172.31.0.0 255.255.0.0 10.20.36.254
ip route 192.168.100.0 255.255.255.0 10.20.36.254
ip route 192.168.101.0 255.255.255.0 10.20.36.254
ip route 206.180.0.0 255.255.255.0 10.20.36.252
ip route 206.180.0.59 255.255.255.255 10.20.36.254
ip http server
ip http authentication local
ip http secure-server
ip nat inside source static tcp 10.20.36.249 23 interface FastEthernet0/1 23
ip nat inside source static tcp 10.20.36.249 22 interface FastEthernet0/1 22
ip nat inside source route-map NAT interface FastEthernet0/1 overload
ip access-list extended Nat
deny   ip 10.20.36.0 0.0.0.255 172.16.12.0 0.0.0.255
permit ip 10.20.36.0 0.0.0.255 any
permit ip 192.168.123.0 0.0.0.255 any
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.20.37.0 0.0.0.255
access-list 102 permit ip 10.20.36.0 0.0.0.255 any
route-map NAT permit 10
match ip address Nat
line con 0
login local
line aux 0
line vty 0 4
login local
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
ntp clock-period 17179022
ntp server 129.6.15.28
end
Everyone's tags (4)
1 REPLY
Purple
Why did you disable CEF on the NAT interfaces ? can you reenable it.
What is not working exactly ?Can you change the port on the outside interface too.
Regards.
Alain
394
