Port Forwarding inbound question - advice please
neilmac
Hi folks.
I have what I think must be a simple config request, I am sure someone can solve this in no time.
I have a non-cisco router with a public WAN address. This is conencted to a 3750 switch internally. The switch is the default gateway for all VLANs, and the gateway router has static routes back to the 3750. The Router provides NAT, no NAT is done on the switch.
My requirement is to port forward port 29 000 so that I can access a server on VLAN4 via this port.
So, I have:
Router: Port 29000 map to 192.168.4.1 (Switch VLAN4 address)
The question is, how do I route port 29000 from the 3750 to the server on 192.168.4.42 ?
I have the following relevant details:
interface Vlan4
ip address 192.168.4.1 255.255.255.0
ip access-group 104 in
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 104 deny   ip 192.168.4.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 104 deny   tcp 192.168.4.0 0.0.0.255 host 192.168.4.1 eq telnet
access-list 104 deny   tcp 192.168.4.0 0.0.0.255 host 192.168.4.1 eq www
access-list 104 deny   tcp 192.168.4.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 104 deny   tcp 192.168.4.0 0.0.0.255 host 192.168.8.1 eq www
access-list 104 deny   tcp 192.168.4.0 0.0.0.255 host 192.168.8.10 eq www
access-list 104 permit ip any any
So, I want to add a line something like
ip source static tcp 192.168.4.42 29000
However I don't know the syntax well enough.
Please would you advise me on what exactly I should add in order to port forward port 29000 incoming form my router, to my server on 192.168.4.42.
Many thanks in advance,
NM
3 Accepted Solutions
Hi NM
as you have permitted all traffic other than the subnets of inside network. on switch wise u dont need to do anything.
permit IP any any
check on the router side as suggested by naidu. NAT/PAT prob.
Hi NM,
It is nothing to do with internal or between vlans as you want the server needs to be accessible from internet on the port 29000. So the way is NAT.
You said in your first post that "The Router provides NAT" what is that router model. Check if you can do NAT on that.
And for your information your 3750 switch which is gateway for your all VLAN's doesnt support NAT.
Please rate the helpfull posts.
Naidu.
Yes it will be like that.
You have a default route 0.0.0.0 0.0.0.0 non-cisco-router-wanIP right?
If the router support NAT then why cant you check if you can configure NAT for this requirement.
What is that router model?
Naidu.
17 Replies 17
Latchum Naidu
What do you mean exactly "port 29000 from the 3750 to the server on 192.168.4.42"
Do you want accept the request from other networks to 192.168.4.42 on port 2900?
Naidu.
I have a device out here on the internet that needs to access my internal server, 192.168.4.42, on port 29000.
192.168.4.42 runs a monitoring program I need to be able to connect to from the WAN.
So,
Incoming traffic on port 29000 from my client pc out here in the remote office: http://WAN_IP:29000
    I
     I
    V
WAN with public IP address
NON Cisco Router - incoming traffic UDP port 29000 is forwarded to 192.168.4.1
LAN
      I
     I
    V
Cisco 3570, gateway for all VLANS, NON NAT Router.
INT VLAN 4 192.168.4.1
     I
     I
    V
Server 192.168.4.42 listening on port 29000
Should be easy ?
NM
You cleared us now what you are going to achieve.
In that case you need to configure a static NAT with a specific public IP on your router to do this port forwarding from internet to your internal server.
If the router is Cisco then the static nat should configure like below...
ip nat inside source static tcp 192.168.4.42 29000 public_ip 29000 extendable
Naidu.
Hi NM
As the switch is doing intervaln routing
if you want to access the server from one vlanX to vlan4 .
just give  destination ip  with port number inside the interface vlan 4.
ex:
access-list 101 permit tcp 192.168.4.0 0.0.0.255 host eq 29000
If u have the access list at destination subnet interface vlan X.
give a permi rule to reach vlan 4 of host 192.168.4.42 on port 29000
please rate the helpful posts
regards
sreek
Srikanth,
He want the server accessble from internet on the required port which is possible with NAT/PAT.
Please read carefully the original post for better understand
Naidu.
Yeah, but the router is NOT Cisco, and is not the gateway for the vlans.
I have port forwarded port 29000 from the router to 192.168.4.1 which is the 3750. Now I need to know how to get it to 192.168.4.42.
The inter VLAN routing is done at the 3750.
The 3750 is not doing NAT, just routing.
The WAN router has default routes to route each subnet back to the 3750.
NM
Hmm, not sure about this.
Here are my access lists, please would you suggest how I should amend it ?
Thanks again
ip subnet zero
ip routing
xxxx- non relevant details removed-xxxx
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip access-group 101 in
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
interface Vlan3
ip address 192.168.3.1 255.255.255.0
ip access-group 103 in
interface Vlan4
interface Vlan5
ip address 192.168.5.1 255.255.255.0
ip access-group 105 in
interface Vlan6
ip address 192.168.6.1 255.255.255.0
ip access-group 106 in
interface Vlan7
ip address 192.168.7.1 255.255.255.0
ip access-group 107 in
interface Vlan8
ip address 192.168.8.1 255.255.255.0
ip access-group 111 in
interface Vlan9
ip address 192.168.9.1 255.255.255.0
ip access-group 108 in
interface Vlan10
description Arqlink Vlan
ip address 192.168.10.1 255.255.255.0
ip access-group 109 in
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.8.10
ip http server
access-list 101 permit ip any any
access-list 102 deny   ip 192.168.2.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 102 deny   ip 192.168.2.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 102 deny   ip 192.168.2.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 102 deny   ip 192.168.2.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 102 deny   ip 192.168.2.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 deny   tcp 192.168.2.0 0.0.0.255 host 192.168.2.1 eq telnet
access-list 102 deny   tcp 192.168.2.0 0.0.0.255 host 192.168.2.1 eq www
access-list 102 deny   tcp 192.168.2.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 102 deny   tcp 192.168.2.0 0.0.0.255 host 192.168.8.1 eq www
access-list 102 deny   tcp 192.168.2.0 0.0.0.255 host 192.168.8.10 eq www
access-list 102 permit ip any any
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 103 deny   ip 192.168.3.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 103 deny   tcp 192.168.3.0 0.0.0.255 host 192.168.3.1 eq telnet
access-list 103 deny   tcp 192.168.3.0 0.0.0.255 host 192.168.3.1 eq www
access-list 103 deny   tcp 192.168.3.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 103 deny   tcp 192.168.3.0 0.0.0.255 host 192.168.8.1 eq www
access-list 103 deny   tcp 192.168.3.0 0.0.0.255 host 192.168.8.10 eq www
access-list 103 permit ip any any
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 105 deny   ip 192.168.5.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 105 deny   tcp 192.168.5.0 0.0.0.255 host 192.168.5.1 eq telnet
access-list 105 deny   tcp 192.168.5.0 0.0.0.255 host 192.168.5.1 eq www
access-list 105 deny   tcp 192.168.5.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 105 deny   tcp 192.168.5.0 0.0.0.255 host 192.168.8.1 eq www
access-list 105 deny   tcp 192.168.5.0 0.0.0.255 host 192.168.8.10 eq www
access-list 105 permit ip any any
access-list 106 permit ip any any
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 107 deny   ip 192.168.7.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 107 deny   tcp 192.168.7.0 0.0.0.255 host 192.168.7.1 eq telnet
access-list 107 deny   tcp 192.168.7.0 0.0.0.255 host 192.168.7.1 eq www
access-list 107 deny   tcp 192.168.7.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 107 deny   tcp 192.168.7.0 0.0.0.255 host 192.168.8.1 eq www
access-list 107 deny   tcp 192.168.7.0 0.0.0.255 host 192.168.8.10 eq www
access-list 107 permit ip any any
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 108 deny   ip 192.168.9.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 108 deny   tcp 192.168.9.0 0.0.0.255 host 192.168.9.1 eq telnet
access-list 108 deny   tcp 192.168.9.0 0.0.0.255 host 192.168.9.1 eq www
access-list 108 deny   tcp 192.168.9.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 108 deny   tcp 192.168.9.0 0.0.0.255 host 192.168.8.1 eq www
access-list 108 deny   tcp 192.168.9.0 0.0.0.255 host 192.168.8.10 eq www
access-list 108 permit ip any any
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.5.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 109 deny   ip 192.168.10.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 109 deny   tcp 192.168.10.0 0.0.0.255 host 192.168.10.1 eq telnet
access-list 109 deny   tcp 192.168.10.0 0.0.0.255 host 192.168.10.1 eq www
access-list 109 deny   tcp 192.168.10.0 0.0.0.255 host 192.168.8.1 eq telnet
access-list 109 deny   tcp 192.168.10.0 0.0.0.255 host 192.168.8.1 eq www
access-list 109 deny   tcp 192.168.10.0 0.0.0.255 host 192.168.8.10 eq www
access-list 109 permit ip any any
access-list 111 deny   ip host 192.168.8.2 192.168.3.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.2 192.168.4.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.2 192.168.5.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.2 192.168.7.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.2 192.168.9.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.2 192.168.10.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.2.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.3.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.4.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.5.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.7.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.9.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.8 192.168.10.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.2.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.3.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.4.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.5.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.7.0 0.0.0.255
access-list 111 deny   ip host 192.168.8.11 192.168.10.0 0.0.0.255
access-list 111 permit ip any any
Hi NM
permit IP any any
Hi NM,
Naidu.
Hi, The router does provide NAT of course, for all of the routed subnets that come to it.
The router is NOT cisco and has a limited feature set.
The default route back to the subnet is VIA the Cisco 3750, so all traffic coming from the router goes to the 3750. The 3750 needs to transfer incoming traffic on 29000 to the server.
The router has a static route: 192.168.4.0, gateway 192.168.8.1
192.168.8.1 is the interface on the 3750 that connects to the router on 192.168.8.10.
If I port forward directly from the router, 29000 -> 192.168.4.42, it does not work.
Should I instead forward 29000 to 192.168.8.1 then have a rule on the 3750 ?
At present, none of this works, I can't access the server.
NM
Naidu.
The router is a hybrid device, quite proprietary, and nothing you would know.
Actually, your answers have prompted me to check a few things, I have another port map set up to another device on another subnet and it's working, so probably the config is sound and it's the server or some other issue.
Let me look into it firther and post back.
Thanks again for the help.
NM
Dear all, thanks for the help - my bad, I was mistakenly given the connection as UDP, I tested with TCP and it worked, the config was correct all along.
NM
Hi NM,
I am little feeling uncomfortable with your rating.
Your actual post is to access one internal LAN server from WAN on port 2900 which is possible with NAT and for which I put my efforts and made clear about that but you didnt recognized it. Even the post to which you rated is said that to follow my suggestion.
But you rated to the post which is completely different answer to your actual post.
Please use the rating whcih will be gift for the whole efforts and time the contributor spent on it.
However feel good to post in CSC as there are lot of experts can help you.
Naidu.
