Port Forwarding to second interface on a Cisco 1841
rickgomez2003
If any of you have time and wouldn't you mind helping me with a cisco 1841 router, I would greatly appreciate it. I need to forward ports 80, 443, 22 to the secondary inside address.
Some background info:
We use ATT for AVPN connectivity.
The T1 comes in on Serial 0/0/0 from remote Datacenter's edge router (AVPN)
The schools internal network is on Fe 0/0 (IP 10.30.58.1/24) this is the IP I use to manage the router
The server I am trying to port forward to is on Fe0/1 (192.168.45.1) the server’s IP is 192.168.45.50
Thank you.
fb_webuser
Level 6
Level 6
analyzing your IP its a private address connected both in your router.... so therefore you dont need port forwarding. what you need is routing from one interface to another. since it is connected to only one router by default router routes a packets from one interface to another. Port Forwarding example:
Datacenter/WAN IP ex: 1.1.1.1
Server IP: 192.168.45.50
Port forward syntax: Router(config)#ip nat inside source static tcp 192.168.45.50 80 1.1.1.1 80 extended
Posted by WebUser Randy Llandelar from Cisco Support Community App
I will test and let you know. Thank you for the reply.
Sorry it did not work. I placed a static rout entry at the DC. and addedd the nat info as stated. If it helps here is part of the router config.
interface Loopback0
ip address 192.168.165.165 255.255.255.255
interface FastEthernet0/0                                !!!!!!!!!!!!! Internal network  !!!!!!!!!!!!!  I manage the router on this interface  !!!!
ip address 10.30.58.1 255.255.255.0
ip helper-address 10.250.1.5
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1                            !!!!!!!!!!!!!!  Server I am tring to forward to  !!!!!!!!!!!!!!!!
description LAN
ip address 192.168.43.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0                                          !!!!!!!   AVPN from datacenter  !!!!!!!!!!!!!!!!!!!!
description T1 PPP Port DHEC.969609.ATI
ip address 192.168.165.1 255.255.255.252
encapsulation ppp
no peer neighbor-route
service-module t1 timeslots 1-24
no cdp enable
ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip route 0.0.0.0 0.0.0.0 192.168.165.2
no ip http server
dialer-list 1 protocol ip permit
