Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Port monitoring on a Catalyst Express 500
I need the ability on the Catalyst Express 500 to monitor traffic from a destination port to a source port. Can this device port monitor?
Re: Port monitoring on a Catalyst Express 500
I just checked out the data sheet of Cat 500 Series switches and found that nothing related to Port Monitoring feature (SPAN) which we usually avail in other switch models..
http://www.cisco.com/en/US/products/ps6545/products_data_sheet0900aecd80322aeb.html
regds
Friend,
Have a look at this document which shows how to configure it on different catalyst switches including the CE500
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml
HTH, rate if it does
Narayan
You must use Cisco Network Assistant with diagnostics (source/destination to add on the destination port)
With the web GUI on the CAT500 you don't have the option for the SPAN.
Ludo
131
