Community Member
port protected in catalyst 2924XL
Dear Experts,
I need some confirmation from you all regarding to the port protection. Please help me to verify my case.
Scenario: I have one switch 2924 with vlan 200 assigned for port 3, 4, and 5 (access vlan). Port 1 is trunk go to router in order to be able to communicate with other vlans.
In port 3,4, and 5 i activated port portected.
What i need to confirm are:
Even in the same VLAN, when port protection activated, port 3, 4, and 5 cannot communicate each other, in any way.
Is it correct?
Is there anyway to make 3 and 4 can communicate but not with port 5 without changing VLAN?
Pls help
Thank you in advance
regards
Randy
Is there
Silver
Re: port protected in catalyst 2924XL
1- yes correct.
2-may be you need to use "private vlan" feature.
with private vlan, ports can be:
-Isolated VLANs-Ports within an isolated VLAN cannot communicate with each other at the Layer 2 level.
-Community VLANs-Ports within a community VLAN can communicate with each other but cannot communicate with ports in other communities at the Layer 2 level.
-Promiscuous- A promiscuous port can communicate with all interfaces, including the isolated and community ports within a PVLAN.
Silver
"Even in the same VLAN, when port protection activated, port 3, 4, and 5 cannot communicate each other, in any way.
Is it correct?
yes correct and they can communicate through layer 3.
"Is there anyway to make 3 and 4 can communicate but not with port 5 without changing VLAN?"
This is possible with private vlan as suggested in other post but i think private vlan cannot be configured in 2924XL
172
