ā09-09-2010 03:19 AM - edited ā03-06-2019 12:53 PM
Can any one please help me to configure port security Cisco 500 Swich ?
There is no CLI mode in this switch?
Thanks in Advance
Siva
ā09-09-2010 04:30 AM
As i understud now, there is no CLI in CE 500 switch. So how can we do the port security in this switch?
Please help......................
ā04-20-2012 07:18 AM
Hi !!!
i try change the configuration the port in the switch catalyst express 500, i need disable switchport port-security, a try with http://10.1.1.1/exec (IP the sw CE500) and save configuration with wr command, if a check the configuration de port is correct but i reboot the switch and check the configuration the port appear the switchport port-security configuration again.
do you know solve this??
thk and regards!!!
