Port Security in CE500 switch ?
Can any one please  help me to configure  port security Cisco 500 Swich ?
There is no CLI mode in this switch?
Thanks in Advance
Siva
Re: Port Security in CE500 switch ?
As i understud now, there is no CLI  in CE 500 switch. So how can we do the port security in this switch?
Please help......................
Hi !!!
i try change the configuration the port in the switch catalyst express 500, i need disable switchport port-security, a try with http://10.1.1.1/exec (IP the sw CE500) and save configuration with wr command, if a check the configuration de port is correct but i reboot the switch and check the configuration the port appear the switchport port-security configuration again.
do you know solve this??
thk and regards!!!
324
