Port Security question
nawas
Level 4
Level 4
I'm currently allowing only one mac address on my port, my config look like this
set port security 1/7 enable age 10 maximum 1 shutdown
I expect that if I unplug a pc from port 1/7 and plug this same pc back in port 1/7 before the 10 min againg timer expires, system should not disable my port. But it doesn't happen that way, port 1/7 goes into shut down mode as soon as i plug in the same pc. Any thoughts?
ariesc_33
once you plugged in the pc back again, check the numbers of mac-address on port 1/7, how many? the switch might still store the mac-address up to 10 minutes after you unplugged, then once plugged in back, the switch thinks that there are 2 mac-address on that port.
show logging
to check the violation logs.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
