04-23-2010 08:17 PM - edited 03-06-2019 10:46 AM
Can you setup port security to automatically learn MAC addresses on a switch? If so, how?
04-23-2010 09:27 PM
You can enable sticky mac port security. Here is an example config for the 3750's
04-25-2010 11:52 PM
Hi ,
Dynamic port security is great but what about when you connect switches to routers or other devices that need to be secured in a way to prevent unauthorized device swapping in the network.
There are two ways to configure a sticky port. The first way being that you configure a static MAC address when configuring port-security on a specific interface. The next way which is more convenient is to configure a “Sticky” MAC address and leave the max MAC addresses to its default value of one. When port-security is configured this way, the first MAC address learned on the switch port will be automatically statically configured into the running-configuration as if you manually specified the MAC address
switchport port-security mac-address h.h.h – This command is executed in interface configuration mode and statically sets a MAC address that allows traffic with the source MAC to traverse the switch.
switchport port-security mac-address sticky – This command is executed in interface configuration mode and configures the port to dynamically learn the MAC address and automatically configure the MAC address as a static MAC address associated with the port.
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
