Webcast-Catalyst9k
Port translations - multiple source and destination - nat to same port
Trying to find a solution to this problem.
1. NAT source IP to a Loopback address based on (1) source IP and (2)destination IP and port.
2. Change destination port from 15101 and 15102 for all traffic to 15100 before traffic leaves router.
Step 1 is pretty simple using route-maps.
Step 2 is not functioning.
I am POSTIVE I had this code running fine on a 2610xm a couple years ago.. it is not working on a 2811.
Everything up to the last 4 IP NAT OUTSIDE statements works... Can anyone think of another method to accomplish step 2?
int loopback1
ip address 172.19.19.1 255.255.255.255
int loopback2
ip address 172.19.19.2 255.255.255.255
int loopback3
ip address 172.19.19.3 255.255.255.255
! router Addressing
fa0/0
ip address 10.0.0.1 255.255.255.0
ip nat inside
s0/0.1
ip address 172.20.180.1 255.255.255.0
ip nat outside
s0/0.2
ip address 172.20.184.1 255.255.255.0
ip nat outside
! ACLs for all 15101 traffic hosts A and B
ip access-list extended Port_15101
 permit tcp 10.0.0.5 255.255.255.255 host 172.20.180.20 eq 15101
 permit tcp 10.0.0.5 255.255.255.255 host 172.20.184.20 eq 15101
permit tcp 10.0.0.6 255.255.255.255 host 172.20.180.20 eq 15101
 permit tcp 10.0.0.6 255.255.255.255 host 172.20.184.20 eq 15101
!ACL for port 15102 traffic from host A
ip access-list extended Port_15102_A
 permit tcp 10.0.0.5 255.255.255.255 host 172.20.180.20 eq 15102
 permit tcp 10.0.0.5 255.255.255.255 host 172.20.184.20 eq 15102
!ACL for port 15102 traffic from host B
ip access-list extended Port_15102_B
 permit tcp 10.0.0.6 255.255.255.255 host 172.20.180.20 eq 15102
 permit tcp 10.0.0.6 255.255.255.255 host 172.20.184.20 eq 15102
! Route maps based on above ACLs
route-map Port_15101_NAT permit 10
match ip address Port_15101
route-map Port_15102_A_NAT permit 10
match ip address Port_15102_A
route-map Port_15102_B_NAT permit 10
match ip address Port_15102_B
! NAT'ing the inside source based on the route map
ip nat inside source route-map Port_15101_NAT interface loopback1 overload
ip nat inside source route-map Port_15102_A_NAT interface loopback2 overload
ip nat inside source route-map Port_15102_B_NAT interface loopback3 overload
! What I thought would work to Translate the ports for all traffic to 15100
ip nat outside source static tcp 172.20.180.20 15100 172.20.180.20 15101 extendable
ip nat outside source static tcp 172.20.180.20 15100 172.20.180.20 15102 extendable
ip nat outside source static tcp 172.20.184.20 15100 172.20.180.20 15101 extendable
ip nat outside source static tcp 172.20.184.20 15100 172.20.180.20 15102 extendable
1 REPLY
Silver
Re: Port translations - multiple source and destination - nat to
Below I am sending you a sample of the syntax to configure PAT, as well as some links on it, hope this is what you are looking for. Ususally the overload option is when you would like many IP's to translate to one IP, and the "overload" command is used
SAMPLE TO OVERLOAD TO ONE INTERFACE
router>enable
router#config t
router(config)#ip route 0.0.0.0 0.0.0.0 x.x.x.x. <-------
NOTE: x.x.x.x is the addres of the ISP, default gateway
router(config)#ip routing
router(config)#ip classless
NAT ( Remember that you need to use a public ip address to enable the
internal LAN to reach the Internet )
router>enable
router#config t
router(config)#ip nat inside source list 120 interface [name of the outisde
interface] overload
router(config)#access-list 120 permit ip [address of the LAN] [inverse mask
of the LAN ] any
router(config)#int [name of the interface ] <---LAN interface
router(config-if)#ip nat inside
router(config-if)#exit
router(config)#int [name of the interface ] <---INTERNET interface
router(config-if)#ip nat outside
For further information click this link
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a00
80091cb9.shtml
192
