Portchannel Trouble
Hi All
I am doing my CCNP certification I was configuring portchannels on GNS3 router with SW interface. some interface shows down. I checked ports is configure fine and mode is on on all interfaces but when ever I check in sh etherchannel summay it show some interface are down . how to resolve this issue plese guide me thanks.
i am getting this error
Switch 1 Config
NL_B1_SW1#sh etherchannel  summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        R - Layer3      S - Layer2
        U - in use
Group Port-channel  Ports
1     Po1(SU)     Fa1/0(D)   Fa1/1(P)
2     Po2(SU)     Fa1/2(P)   Fa1/3(P)
Switch 2 Config
NL_B1_SW2#sh etherchannel summary
        U - in use
Switch 3 Config
NL_B1_SW3#sh etherchannel summary
        U - in use
1     Po1(SD)     Fa1/0(D)   Fa1/1(D)
VIP Super Bronze
Portchannel Trouble
Can you post your configs?
Portchannel Trouble
For Switch 1 Config
Building configuration...
Current configuration : 125 bytes
interface Port-channel1
switchport trunk allowed vlan 1,64,66,68,69,71,1002-1005
switchport mode trunk
duplex full
end
NL_B1_SW1#sh confi
NL_B1_SW1#sh configuration
Using 2361 out of 155640 bytes
version 12.4
hostname NL_B1_SW1
boot-start-marker
boot-end-marker
enable secret 5 $1$GfK6$XK/fHlJKoZnnGDabSMmuU1
no aaa new-model
memory-size iomem 5
ip cef
ip domain name nuggetlabs.com
ip name-server 4.2.2.2
ip name-server 4.2.2.3
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp file nvram:vlan.dat
username admin secret 5 $1$RxI8$o4F82juKyDQ1w.5HM6Mqv0
ip ssh version 2
duplex full
interface Port-channel2
duplex full
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
duplex full
channel-group 1 mode on
interface FastEthernet1/1
duplex full
interface FastEthernet1/2
duplex full
channel-group 2 mode on
interface FastEthernet1/3
duplex full
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
shutdown
interface Vlan71
ip address 10.1.71.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
mgcp behavior g729-variants static-pt
banner motd ^CC
DO NOT LOGIN
^C
line con 0
exec-timeout 180 0
password cisco
logging synchronous
line aux 0
line vty 0 4
password cisco
login local
ntp server 64.73.32.135
end
For Switch 2 Config
Using 1626 out of 155640 bytes
version 12.4
hostname NL_B1_SW2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
switchport trunk allowed vlan 1,64,66,69,71,1002-1005
duplex full
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex full
duplex full
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
For Switch 3 Config
version 12.4
hostname NL_B1_SW3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
duplex full
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
duplex full
duplex full
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
I have attached all the 3 switches configuration thanks in advance for your help.
faisal
VIP Super Bronze
Portchannel Trouble
Can you add command:
to the physical ports and Etherchannel interfaces?
Portchannel Trouble
yes I did
I add this command and its accepted but not showing on interface output.
Portchannel Trouble
Switch 3 Switchport status
NL_B1_SW3#sh interfaces port-channel 1 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: 1,64,66,69,71,1002-1005
Trunking VLANs Active: none
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Switch 2 Switchport status
Switchport: Enabled
Operational Mode: trunk
Operational Trunking Encapsulation: dot1q
Trunking VLANs Active: 1,64,66,69,71
Voice VLAN: none
Switch 1 Switchport Status
Switchport: Enabled
Trunking VLANs Enabled: 1,64,66,68,69,71,1002-1005
Trunking VLANs Active: 1,64,66,68-69,71
Voice VLAN: none
may be you find some problem in this out put
VIP Super Bronze
Portchannel Trouble
For simplicity, can you try configuring the Etherchannel between just 2 switches and not 3
Also can you use LACP instead of on
So switch-1
channel-group 1 mode active
switch-2
channel-group 1 mode passive
If this does not work, can you create a new portchannel and apply the LACP config?
Portchannel Trouble
hi
its not giving me these options as I am running an IOS version on GNS3 . and I am doing practice lab directly watching the jeremey videos. but he didnot get any error and I got this interface bundled problem.
Bronze
Re: Portchannel Trouble
These commands will be helpful
show etherchannel 1 port-channel
show int Fa0/1
show int status err-disabled
Portchannel Trouble
I just tried to bundle the interfaces but its not bundled i dun know why. I am watching jeremy video and doing step by step work but I got this issue right now .
           Port-channels in the group:
Port-channel: Po1
Age of the Port-channel   = 00d:02h:28m:45s
Logical slot/port   = 8/0           Number of ports = 1
GC                  = 0x00010001      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Ports in the Port-channel:
Index   Port   EC state
  0     Fa1/1    on
Time since last port bundled:    00d:01h:05m:35s    Fa1/1
Time since last port Un-bundled: 00d:01h:05m:35s    Fa1/1
Hall of Fame Super Gold
Portchannel Trouble
Remove the Po1 configuration of both Fa1/0 and Fa1/1.  Does the link go up?
Portchannel Trouble
got the solution
actually configurations are right I have restart the switch thats why configuration doesnot take place
well thanks for guielines
I really appericiate all of your help
regards
faisal
921
