Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Portfast bpdu-guard vs bpdu-guard
What is the difference between these two commands?
set spantree bpdu-guard mod/port {enable | disable | default}
set spantree portfast bpdu-guard mod/port {enable | disable | default}
Re: Portfast bpdu-guard vs bpdu-guard
None as far as I know (I'm not catos expert though). Bpduguard was initially based on portfast. It was subsequently modified to be *not* dependent on portfast (at least for its port configuration). I guess the portfast version should be deprecated.
Francois
Well as far as i know,if the portfast is applied on the access port and you connect a switch ,there is scope for loop to exists since the port direcly goes into forwarding state,if we apply bpdu guard along with the portfast ,the port will go into err-disable as soon as it will receive a BPDU.
131
