Ports do not traffic but are 'up' - Troubleshooting Switch 3850 in Stack
Hi, I had a problem in a Switch 3850 in Stack. It stopped working almost at midnight. Symptoms were:
- No traffic through every port in that switch
- Port showed to be 'up'.
- Remote access to management IP address of the switch was available.
Early in the morning, I checked the logs but there is no warning or alert at the failure time. The crashinfo command shows an empty file.
I used the reload command to reload the switch, and it is working fine now.
What else can I do to discover the reason of the problem? How can I know It won't happen again?
Thanks in advance.
Reynaldo Lopez
Everyone's tags (3)
Check that the stackwise
Check that the stackwise cables are secure on the backside. I would open up a TAC case and send them the sh tech to see if they can see anything. You can also use the online sh tech parser and see what it spits out.
Another great tool is the Cisco CLI Analyzer...check it out.
Hello
Hello
Did the switch(s) reload or just stop forwarding traffic?
Have you recently upgrade the ios or introduced an additional switch to the stack?
Check the iOS and feature sets for possible bugs on Cisco support?
Check current CPU/memory utilisation also
res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
35
