ports don't up
Asad Abbas
I have two 2950 catalyst switch when i power up these switches and want to make trunk between these swithes using cross over cable the ports not up not light blink when i check status of interface
Fa0/1 is down, line protocol is down (notconnect
but when i connect this port to huawei switch port then port going up
this is screen text
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA5, RELEASE SOFTWARE                                              (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 13-Jul-05 22:09 by antonino
Image text-base: 0x80010000, data-base: 0x80566000
Initializing flashfs...
flashfs[1]: 358 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4668928
flashfs[1]: Bytes available: 3072512
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
POST: FRONT-END LOOPBACK TEST : Passed
cisco WS-C2950T-24 (RC32300) processor (revision R0) with 21025K bytes of memory                                             .
Processor board ID FOC0942Z2FJ
Last reset from system-reset
Running Enhanced Image
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:15:F9:3F:2A:C0
Motherboard assembly number: 73-6114-10
Power supply part number: 34-0965-01
Motherboard serial number: FOC09412WTL
Power supply serial number: DAB0937FZAG
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950T-24
System serial number: FOC0942Z2FJ
Press RETURN to get started!
00:00:16: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:18: %SYS-5-CONFIG_I: Configured from memory by console
00:00:18: %SYS-5-RESTART: System restarted --
00:00:18: %SNMP-5-COLDSTART: SNMP agent on host switch2 is undergoing a cold sta                                             rt
00:00:19: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively do                                             wn
00:00:20: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state t
plz help
cadet alain
Can you post the output of sh int f0/1 switchport  and sh int f0/1 status
Alain
glen.grant
  I would check to make sure you are actually using a crossover cable and not a straight .
        solved my swith ports are loose
thanks
