04-06-2007 12:25 PM - edited 03-05-2019 03:21 PM
We have a need to change IP addresses on a group of servers. Unfortunately we need time to change the clients to point to these new IP's as well. Is there a possible way, maybe using NAT so that clients can telnet to the new address as well as the old address until we can get them all changed to point at the new addresses?
04-07-2007 07:28 AM
Friend,
You can Change the IP address of the server and then configure static NAT on the edge device to the old ip address
The Clients will still continue to connect to the old IP till the time you have them change the ip addresses
HTH, rate if it does
Narayan
04-09-2007 04:38 AM
Thanks for your reply. A static NAT entry is what I thought of as well. With the static entry I can ping both the new and the old IP address but I can not telnet, ftp, etc. to the "old" IP address.
